duplicati serializes backups on a given system, but can it serialize across systems?
I envision something along these lines…
backup on server “B” is configured to check status on server “A”
server “A” responds with a simple yes/no answer indicating backups are running and/or pending; i.e. idle yes/no?
when server “A” responds that no backups are running/pending, the backup on server “B” proceeds
There are several obvious enhancements to the above:
option to start backups after an amount of time even if server “A” never reports that it is idle
how to handle if server “A” never responds
this could even be extended to check specific backups on server “A”, although that starts getting into potential authorization/security issues
Generally, Duplicati is designed to be “single instance” and does not interact with other Duplicati instances (local or remote).
You can do something like that with ServerUtil , where you can query a Duplicati instance with a commandline tool.
You can ask for the state of Server B, and trigger a backup on Server A for instance, but you need to open at least one of the instances to listen on a public network interface (it uses loopback only by default).
I would think a script of sorts could handle these actions, using ServerUtil as the building block.
asman
June 25, 2025, 7:03pm
3
You could use the feature to trigger scripts on start / finish of a job (run-script-after) to trigger webhooks.
I have a simple script that runs a curl command to trigger a webhook on my homeassistant server. Then I switch off the backup drive via smart plug.
I also start the backup itself via webhook (on a Linux / docker Server)
See here:
so just fyi, after a lot of tinkering, this is the solution I have came to. It involves homeassistant (which I have anyhow) and installing webhook on the file server (=docker host)
Every day on 0:00 the homeassistant server triggers an automation:
switch on backup drive (via switchable power socket)
trigger webhook script on file server that:
- mounts the backup drive
- waits 10s
- starts duplicati container
duplicati has all backups scheduled on 0:00 so they should run immediately
On 0:05 …
How to use a webhook to trigger something directly on duplicati, I did not try. Probably this will work with Server util or duplicati-cli.
