Hello,
I’m trying duplicati for the first time.
I have configured 3 backups, but one of the 3 backups failed.
The error log is as follows.
What the problem is?
System.AggregateException: One or more errors occurred. (Error getting response stream (ReadDoneAsync2): ReceiveFailure (Error getting response stream (ReadDoneAsync2): ReceiveFailure) (One or more errors occurred. (Error getting response stream (ReadDoneAsync2): ReceiveFailure))) —> System.AggregateException: Error getting response stream (ReadDoneAsync2): ReceiveFailure (Error getting response stream (ReadDoneAsync2): ReceiveFailure) (One or more errors occurred. (Error getting response stream (ReadDoneAsync2): ReceiveFailure)) —> System.Net.WebException: Error getting response stream (ReadDoneAsync2): ReceiveFailure
at System.Net.WebResponseStream.InitReadAsync (System.Threading.CancellationToken cancellationToken) [0x00107] in :0
at System.Net.WebOperation.Run () [0x001f2] in :0
at System.Net.WebCompletionSource1[T].WaitForCompletion () [0x000b1] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0 at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task
1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x00118] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0 at Duplicati.Library.Utility.AsyncHttpRequest+AsyncWrapper.GetResponseOrStream () [0x0004d] in <ae4a5c68f78041539efc9420d056bd22>:0 at Duplicati.Library.Utility.AsyncHttpRequest.GetResponse () [0x00044] in <ae4a5c68f78041539efc9420d056bd22>:0 at Duplicati.Library.JSONWebHelper.GetResponse (Duplicati.Library.Utility.AsyncHttpRequest req, System.Object requestdata) [0x000c9] in <430fb651568b4158b0aeeaccca31dfe8>:0 at Duplicati.Library.JSONWebHelper.ReadJSONResponse[T] (Duplicati.Library.Utility.AsyncHttpRequest req, System.Object requestdata) [0x00000] in <430fb651568b4158b0aeeaccca31dfe8>:0 at Duplicati.Library.JSONWebHelper.GetJSONData[T] (System.String url, System.Action
1[T] setup, System.Action1[T] setupbodyreq) [0x00024] in <430fb651568b4158b0aeeaccca31dfe8>:0 at Duplicati.Library.JSONWebHelper.PostAndGetJSONData[T] (System.String url, System.Object item, System.String method) [0x00023] in <430fb651568b4158b0aeeaccca31dfe8>:0 at Duplicati.Library.Backend.Backblaze.B2.List () [0x00069] in <fb8c929d985941ecb798c075f875ee67>:0 at Duplicati.Library.Backend.Backblaze.B2.PutAsync (System.String remotename, System.IO.Stream stream, System.Threading.CancellationToken cancelToken) [0x0023b] in <fb8c929d985941ecb798c075f875ee67>:0 at Duplicati.Library.Main.Operation.Backup.BackendUploader.DoPut (Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Interface.IBackend backend, System.Threading.CancellationToken cancelToken) [0x00426] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.Backup.BackendUploader+<>c__DisplayClass20_0.<UploadFileAsync>b__0 () [0x0010a] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.Backup.BackendUploader.DoWithRetry (System.Func
1[TResult] method, Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x00198] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.DoWithRetry (System.Func1[TResult] method, Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x003c1] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.Backup.BackendUploader.UploadFileAsync (Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x000da] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.Backup.BackendUploader.UploadBlockAndIndexAsync (Duplicati.Library.Main.Operation.Backup.VolumeUploadRequest upload, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x001df] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.Backup.BackendUploader.<Run>b__13_0 (<>f__AnonymousType12
1[j__TPar] self) [0x00780] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.b__13_0 (<>f__AnonymousType121[<Input>j__TPar] self) [0x007d7] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at CoCoL.AutomationExtensions.RunTask[T] (T channels, System.Func
2[T,TResult] method, System.Boolean catchRetiredExceptions) [0x000d5] in <9a758ff4db6c48d6b3d4d0e5c2adf6d1>:0
at Duplicati.Library.Main.Operation.BackupHandler.FlushBackend (Duplicati.Library.Main.BackupResults result, CoCoL.IWriteChannel1[T] uploadtarget, System.Threading.Tasks.Task uploader) [0x000f2] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00cb2] in <9cab5b8f1b4f49ec980acae8e278968b>:0 --- End of inner exception stack trace --- at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x01048] in <9cab5b8f1b4f49ec980acae8e278968b>:0 --- End of inner exception stack trace --- at CoCoL.ChannelExtensions.WaitForTaskOrThrow (System.Threading.Tasks.Task task) [0x0005d] in <9a758ff4db6c48d6b3d4d0e5c2adf6d1>:0 at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00009] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x0004b] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action
1[T] method) [0x0026f] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Controller.Backup (System.String inputsources, Duplicati.Library.Utility.IFilter filter) [0x00074] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Server.Runner.Run (Duplicati.Server.Runner+IRunnerData data, System.Boolean fromQueue) [0x00349] in <30a34d71126b48248d040dda634ddad9>:0
—> (Inner Exception #0) System.AggregateException: Error getting response stream (ReadDoneAsync2): ReceiveFailure (Error getting response stream (ReadDoneAsync2): ReceiveFailure) (One or more errors occurred. (Error getting response stream (ReadDoneAsync2): ReceiveFailure)) —> System.Net.WebException: Error getting response stream (ReadDoneAsync2): ReceiveFailure
at Duplicati.Library.Main.Operation.BackupHandler.FlushBackend (Duplicati.Library.Main.BackupResults result, CoCoL.IWriteChannel1[T] uploadtarget, System.Threading.Tasks.Task uploader) [0x000f2] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00cb2] in <9cab5b8f1b4f49ec980acae8e278968b>:0 --- End of inner exception stack trace --- at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x01048] in <9cab5b8f1b4f49ec980acae8e278968b>:0 ---> (Inner Exception #0) System.Net.WebException: Error getting response stream (ReadDoneAsync2): ReceiveFailure at System.Net.WebResponseStream.InitReadAsync (System.Threading.CancellationToken cancellationToken) [0x00107] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0 at System.Net.WebOperation.Run () [0x001f2] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0 at System.Net.WebCompletionSource
1[T].WaitForCompletion () [0x000b1] in :0
at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func
1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x00118] in :0
at Duplicati.Library.Utility.AsyncHttpRequest+AsyncWrapper.GetResponseOrStream () [0x0004d] in :0
at Duplicati.Library.Utility.AsyncHttpRequest.GetResponse () [0x00044] in :0
at Duplicati.Library.JSONWebHelper.GetJSONData[T] (System.String url, System.Action1[T] setup, System.Action
at Duplicati.Library.Backend.Backblaze.B2.List () [0x00069] in :0
at Duplicati.Library.Backend.Backblaze.B2.PutAsync (System.String remotename, System.IO.Stream stream, System.Threading.CancellationToken cancelToken) [0x0023b] in :0
at Duplicati.Library.Main.Operation.Backup.BackendUploader+<>c__DisplayClass20_0.b__0 () [0x0010a] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.DoWithRetry (System.Func1[TResult] method, Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x00198] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.Backup.BackendUploader.DoWithRetry (System.Func
at Duplicati.Library.Main.Operation.Backup.BackendUploader.b__13_0 (<>f__AnonymousType121[<Input>j__TPar] self) [0x00780] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.Backup.BackendUploader.<Run>b__13_0 (<>f__AnonymousType12
1[j__TPar] self) [0x007d7] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at CoCoL.AutomationExtensions.RunTask[T] (T channels, System.Func2[T,TResult] method, System.Boolean catchRetiredExceptions) [0x000d5] in <9a758ff4db6c48d6b3d4d0e5c2adf6d1>:0 at Duplicati.Library.Main.Operation.BackupHandler.FlushBackend (Duplicati.Library.Main.BackupResults result, CoCoL.IWriteChannel
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00cb2] in <9cab5b8f1b4f49ec980acae8e278968b>:0 <—
—> (Inner Exception #1) System.AggregateException: One or more errors occurred. (Error getting response stream (ReadDoneAsync2): ReceiveFailure) —> System.Net.WebException: Error getting response stream (ReadDoneAsync2): ReceiveFailure
at Duplicati.Library.Main.Operation.BackupHandler.FlushBackend (Duplicati.Library.Main.BackupResults result, CoCoL.IWriteChannel1[T] uploadtarget, System.Threading.Tasks.Task uploader) [0x000f2] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00cb2] in <9cab5b8f1b4f49ec980acae8e278968b>:0 --- End of inner exception stack trace --- ---> (Inner Exception #0) System.Net.WebException: Error getting response stream (ReadDoneAsync2): ReceiveFailure at System.Net.WebResponseStream.InitReadAsync (System.Threading.CancellationToken cancellationToken) [0x00107] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0 at System.Net.WebOperation.Run () [0x001f2] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0 at System.Net.WebCompletionSource
