i need help
when I try to restore the information, the message from recreated database has mising blocks and 4 broken filelists appears and does not retrieve any information
i need help
Missing blocks are never good news. That might be actual file data. How big a restore do you need? Possibly you can steer around damage with direct restore which builds a partial temporary database.
Getting backups back up again will take a full database. Was there a prior problem before Recreate?
Are old backup versions quite important? If so, other tools exist. If not, starting again may be easiest.
