Recently one of backups started failing. I decided to try and recreate my local database to make sure things were in order. When I run a recreate it runs for 12+ hours but then it eventually fails:
Failed to process index file: duplicati-iea25543756e14548add40ac3c3ffabea.dindex.zip.aes
Duplicati.Library.Interface.FileMissingException: The requested file does not exist
at Duplicati.Library.Main.AsyncDownloader+AsyncDownloaderEnumerator+AsyncDownloadedFile.get_TempFile () [0x00008] in <533fc6a2ce6a49e5868bdd6f335ced4e>:0
at Duplicati.Library.Main.Operation.RecreateDatabaseHandler.DoRun (Duplicati.Library.Main.Database.LocalDatabase dbparent, System.Boolean updating, Duplicati.Library.Utility.IFilter filter, Duplicati.Library.Main.Operation.RecreateDatabaseHandler+NumberedFilterFilelistDelegate filelistfilter, Duplicati.Library.Main.Operation.RecreateDatabaseHandler+BlockVolumePostProcessor blockprocessor) [0x00b24] in <533fc6a2ce6a49e5868bdd6f335ced4e>:0
So I tried doing a repair:
The database is marked as "in-progress" and may be incomplete.
Found 6 missing blocklisthash entries, repairing
System.Exception: Missing block for blocklisthash: aCKfgS7vTUo8zpylWMHAiogs5wyL52sGtZ9e+uc3xYg=
at Duplicati.Library.Main.Database.LocalRepairDatabase.FixMissingBlocklistHashes (System.String blockhashalgorithm, System.Int64 blocksize) [0x00246] in <533fc6a2ce6a49e5868bdd6f335ced4e>:0
at Duplicati.Library.Main.Operation.RepairHandler.RunRepairCommon () [0x000ce] in <533fc6a2ce6a49e5868bdd6f335ced4e>:0
at Duplicati.Library.Main.Operation.RepairHandler.Run (Duplicati.Library.Utility.IFilter filter) [0x00147] in <533fc6a2ce6a49e5868bdd6f335ced4e>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass21_0.<Repair>b__0 (Duplicati.Library.Main.RepairResults result) [0x0001c] in <533fc6a2ce6a49e5868bdd6f335ced4e>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x00072] in <533fc6a2ce6a49e5868bdd6f335ced4e>:0
Return code: 100
So I’m stuck now. I can’t do a repair, I can’t do a recreate, and I can’t run a backup. Any thoughts on how to get unstuck? The backup is 1.2 TB, so I’m hoping to not have to start over.
