Happened another time just now, during a backup job to Mega. What’s wrong?
System.ArgumentNullException: Il valore non può essere null.
Nome parametro: uriString
in Duplicati.Library.Main.AsyncDownloader.AsyncDownloaderEnumerator.AsyncDownloadedFile.get_TempFile()
in Duplicati.Library.Main.Operation.CompactHandler.DoCompact(LocalDeleteDatabase db, Boolean hasVerifiedBackend, IDbTransaction& transaction, BackendManager sharedBackend)
in Duplicati.Library.Main.Operation.DeleteHandler.DoRun(LocalDeleteDatabase db, IDbTransaction& transaction, Boolean hasVerifiedBacked, Boolean forceCompact, BackendManager sharedManager)
in Duplicati.Library.Main.Operation.BackupHandler.CompactIfRequired(BackendManager backend, Int64 lastVolumeSize)
in Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__19.MoveNext()
--- Fine traccia dello stack da posizione precedente dove è stata generata l'eccezione ---
in System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
in CoCoL.ChannelExtensions.WaitForTaskOrThrow(Task task)
in Duplicati.Library.Main.Controller.<>c__DisplayClass13_0.<Backup>b__0(BackupResults result)
in Duplicati.Library.Main.Controller.RunAction[T](T result, String[]& paths, IFilter& filter, Action`1 method)
in Duplicati.Library.Main.Controller.Backup(String[] inputsources, IFilter filter)
in Duplicati.Server.Runner.Run(IRunnerData data, Boolean fromQueue)
Edit: this time the log does not contain any “failed to process file” occurrence.
Here is the completed text sent via email:
Failed: Il valore non può essere null.
Details: System.ArgumentNullException: Il valore non può essere null.
Log data:
2019-08-09 19:56:35 +02 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
