Failed to connect
Because Stack stops I switched to OneDrive. I also want to use Duplicati for my Backups there, but after creating the AuthID I keep getting error 410.
Welcome to the forum @addelamar
Does your Destination screen 2 say “Microsoft OneDrive” or “Microsoft OneDrive v2” which is required?
What Duplicati version is this? I think 2.0.4.5/23 supported both, but Microsoft discontinued the old version.
Like this?
OneDrive failing : “The remote server returned an error: (410) Gone.”
2.0.5.1 removed support for the obsolete OneDrive and fixed various issues.
If you are on Linux, the mono package version requirement for it went up to 5.
So just update. And it works! What a simple solution. Why can’t I think of such a thing myself? Thanks a lot for your help. Ad
