Hello
I’m trying to add a backup destination but I’m getting an error
Failed to connect: The URI prefix is not recognized.
I tried installing Duplicati on a VM and adding the same backup destination and it worked fine I will have Log down below
Request for http://127.0.0.1:8200/api/v1/remoteoperation/test gave error
System.NotSupportedException: The URI prefix is not recognized.
at System.Net.WebRequest.Create (System.Uri requestUri, System.Boolean useUriBase) [0x000ae] in <9c6e2cb7ddd8473fa420642ddcf7ce48>:0
at System.Net.WebRequest.Create (System.String requestUriString) [0x00014] in <9c6e2cb7ddd8473fa420642ddcf7ce48>:0
at Duplicati.Library.Backend.WEBDAV.CreateRequest (System.String remotename) [0x00026] in <5df020eccaa84287a3c79d1a4bf95fc9>:0
at Duplicati.Library.Backend.WEBDAV.ListWithouExceptionCatch () [0x00000] in <5df020eccaa84287a3c79d1a4bf95fc9>:0
at Duplicati.Library.Backend.WEBDAV.List () [0x00000] in <5df020eccaa84287a3c79d1a4bf95fc9>:0
at Duplicati.Library.Backend.WEBDAV.Test () [0x00000] in <5df020eccaa84287a3c79d1a4bf95fc9>:0
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.TestConnection (System.String url, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) [0x000b7] in <156011ea63b34859b4073abdbf0b1573>:0
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.POST (System.String key, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) [0x00094] in <156011ea63b34859b4073abdbf0b1573>:0
at Duplicati.Server.WebServer.RESTHandler.DoProcess (Duplicati.Server.WebServer.RESTMethods.RequestInfo info, System.String method, System.String module, System.String key) [0x00289] in <156011ea63b34859b4073abdbf0b1573>:0
Reporting error gave error
System.ObjectDisposedException: Can not write to a closed TextWriter.
at System.IO.StreamWriter.Flush (System.Boolean flushStream, System.Boolean flushEncoder) [0x00008] in <533173d24dae460899d2b10975534bb0>:0
at System.IO.StreamWriter.Flush () [0x00006] in <533173d24dae460899d2b10975534bb0>:0
at Duplicati.Server.WebServer.RESTHandler.DoProcess (Duplicati.Server.WebServer.RESTMethods.RequestInfo info, System.String method, System.String module, System.String key) [0x003bc] in <156011ea63b34859b4073abdbf0b1573>:0
Duplicati version: 2.0.6.3
OS: Ubuntu 20.04
Thank You
