I am trying to connect to a Microsoft SharePoint v2 destination. After obtaining the AuthID and providing the site-id, when I test the connection I get the error “Failed to connect: Specified cast is not valid.” See image below. Does anyone have a solution or can educate me on what “cast” is so I can search myself?
I don’t use SharePoint so I may be off base here, but you almost certainly don’t want to put the protocol specifier in your destination path field. Try removing the “sharepoint://” portion and see if it makes any difference on your connection test.
