Hello,
Love duplicati but am having an issue. I was backing up an older computer with duplicati to both B2 and Minio endpoints. I got a new computer and copied all the files over, and migrated Duplicati’s settings for both endpoints. I did not move over the Duplicati database.
On the new computer I had it Recreate the database and after that was done it seemed to back up OK.
But after a day or two I started getting the error:
Failed: Detected non-empty blocksets with no associated blocks
This happened on both endpoints.
I then had it Recreate the database again, and again it seemed to back up successfully, only to start generating that error the next day.
Does anyone know why it is getting in this state (and what debugging info might be needed) and what I can do to fix this? Right now it is not successfully backing up this new computer. Thanks.
