Separate question. While I was testing my changes, there was a condition that I did not handle. The Duplicati UI indicated that there were warnings, but nowhere in the UI could I find them. I was not until I set --log-file was I able to see the actual issue. Should I be seeing this in the UI as well? If so, is there a setting to change?
Also, here’s the first result from succeeding with JSON conversion. There are some things logged that are not currently logged (e.g. BackedStatistics, BackendWriter, MessageSink, etc.). I’m wondering if I should look at stripping those out?
result.json
"DeletedFiles": 0,
"DeletedFolders": 0,
"ModifiedFiles": 0,
"ExaminedFiles": 1,
"OpenedFiles": 0,
"AddedFiles": 0,
"SizeOfModifiedFiles": 0,
"SizeOfAddedFiles": 0,
"SizeOfExaminedFiles": 2261057,
"SizeOfOpenedFiles": 0,
"NotProcessedFiles": 0,
"AddedFolders": 0,
"TooLargeFiles": 0,
"FilesWithError": 0,
"ModifiedFolders": 0,
"ModifiedSymlinks": 0,
"AddedSymlinks": 0,
"DeletedSymlinks": 0,
"PartialBackup": false,
"Dryrun": false,
"MainOperation": "Backup",
"CompactResults": null,
"DeleteResults": null,
"RepairResults": null,
"TestResults": {
"MainOperation": "Test",
"Verifications": [
"Key": "duplicati-20180123T225148Z.dlist.zip",
"Value": []
"Key": "duplicati-ic59217ecf022474588ff70eaa219152f.dindex.zip",
"Value": []
"Key": "duplicati-b19f77f2d1f7d4181894a68ca40602c66.dblock.zip",
"Value": []
"VerboseOutput": false,
"VerboseErrors": false,
"EndTime": "2018-01-24T00:02:15.4852709Z",
"BeginTime": "2018-01-24T00:02:15.1339592Z",
"Duration": "00:00:00.3513117",
"MessageSink": null,
"Errors": null,
"RemoteCalls": 5,
"BytesUploaded": 0,
"BytesDownloaded": 1480010,
"FilesUploaded": 0,
"FilesDownloaded": 3,
"FilesDeleted": 0,
"RetryAttempts": 0,
"UnknownFileSize": 0,
"UnknownFileCount": 0,
"KnownFileCount": 3,
"KnownFileSize": 1480010,
"LastBackupDate": "2018-01-23T19:21:48-03:30",
"BackupListCount": 1,
"TotalQuotaSpace": 249690058752,
"FreeQuotaSpace": 139679543296,
"AssignedQuotaSpace": -1,
"BeginTime": "2018-01-24T00:02:13.8148129Z",
"Errors": null
"BackendWriter": {
"RemoteCalls": 5,
"BytesUploaded": 0,
"FilesUploaded": 0,
"FilesDeleted": 0,
"RetryAttempts": 0,
"Errors": null
"EndTime": "2018-01-24T00:02:15.8269689Z",
"BeginTime": "2018-01-24T00:02:13.8138123Z",
"Duration": "00:00:02.0131566",
"MessageSink": {
"QuietConsole": false,
"Output": {
"Encoding": {
"m_isReadOnly": true,
"encoderFallback": {
"MaxCharCount": 1
"decoderFallback": {
"MaxCharCount": 1
"m_codePage": 850,
"dataItem": null,
"Encoding+m_codePage": 850,
"Encoding+dataItem": null,
"maxCharSize": 1
"FormatProvider": "en-US",
"NewLine": "\r\n"
"BackendProgress": {},
"OperationProgress": {}
"Messages": [],
"Warnings": [],
"Errors": [],
"RemoteCalls": 5,
"BytesUploaded": 0,
"FilesUploaded": 0,
"FilesDeleted": 0,
"RetryAttempts": 0,
"Errors": null
"BackendWriter": {
"RemoteCalls": 5,
"BytesUploaded": 0,
"FilesUploaded": 0,
"FilesDeleted": 0,
"RetryAttempts": 0,
"Errors": null
