Disaster recovery of large backups: The original hard drive is destroyed, along with the duplicati databases. There are several backups of different directories. The largest backup is 1.5 TB in size.
I have made several attempts to restore the largest backup. I have now set up a separate machine just for recovery. The backup files are now on a local SSD. I started the recovery from the command line. Below is an extract from the log file.
Duplicati takes about 40 minutes for each dblock. With nearly 31000 dblock files that would be about 2.5 years, until this step is completed. I hope my hardware will last that long.
Is there any way to speed up the process?
If I have to restart the computer during this time, is there a way to continue the recovery or does it start all over again?
Thanks,
Franki
2023-10-20 05:40:52 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Completed: duplicati-b4844e3b283af402dbafd2bebb7f72352.dblock.zip.aes (49,97 MB)
2023-10-20 06:17:56 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-b3014411e1a42418d885639d7dad35431.dblock.zip.aes (49,99 MB)
2023-10-20 06:17:56 +02 - [Verbose-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-ProcessingBlocklistVolumes]: Pass 3 of 3, processing blocklist volume 18 of 30986
2023-10-20 06:18:04 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Completed: duplicati-b3014411e1a42418d885639d7dad35431.dblock.zip.aes (49,99 MB)
2023-10-20 06:55:29 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-bebfe15e488f44ab7aa51b23228c78702.dblock.zip.aes (49,96 MB)
2023-10-20 06:55:29 +02 - [Verbose-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-ProcessingBlocklistVolumes]: Pass 3 of 3, processing blocklist volume 19 of 30986
2023-10-20 06:55:37 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Completed: duplicati-bebfe15e488f44ab7aa51b23228c78702.dblock.zip.aes (49,96 MB)
2023-10-20 07:33:03 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-b37a20674288e4c7f9a4b088104778032.dblock.zip.aes (49,91 MB)
2023-10-20 07:33:03 +02 - [Verbose-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-ProcessingBlocklistVolumes]: Pass 3 of 3, processing blocklist volume 20 of 30986
2023-10-20 07:33:10 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Completed: duplicati-b37a20674288e4c7f9a4b088104778032.dblock.zip.aes (49,91 MB)
