how can I exclude folders when using compare command? It seems that folders are included because some metadata on them changed (modification date). For example, when I modify test.txt in folder testFolder, the compare will show that testFolder was modified and testFolder\test.txt was modified. I don’t care about folder modification, it seems of no value, just noise.
Thank you for Duplicati and your support.
Kind regards, Jan
BTW, using --exclude=“c:*\” throws System.Data.SQLite.SQLiteException (0x80004005): SQL logic error or missing data base near ""."": syntax error
It seems to crash no matter what you write in --exclude or --include. I could be mistaken but looking through Git code in LocalListChangesDatabase.cs, method AddFromDb() it seems that there are excessive quotes around inner select in:
using(var rd = cmd.ExecuteReader(string.Format(@“SELECT ““A””.”“Path”", ““A””."“FileHash”", ““A””."“MetaHash”", ““A””."“Size”", ““A””."“Type”" FROM “”{0}"" A WHERE ““A””."“FilesetID”" = ?", combined), filesetId))
I would like to but I cannot build/debug or otherwise verify the change, I am Java guy. I will happily leave the fame of fixing this bug to someone else
