Exception after 2.4.0.0 Upgrade
I recently upgraded my long-standing install to 2.4.0.0, using the windows service option. I did all the re-configuration required (pointing to the old database folder, adding the database encryption key). Now I am running into a new problem:
For one of my backups, the source data was on a mapped network drive. Now that duplicati is running as a service, this mapping is no longer active. So I am trying to edit the “Source Data” to use the UNC path. The problem is, that whether I add the UNC Path (say, \\10.0.0.5\Data) as a “Manually type path” under the “File System” source, or as a “Windows Share SMB”, the following happens:
  1. I am able to add the path and the “Test Now” is successful
  2. In the SMB screen, I am able to hit the “Browse” button and see the folder structure
  3. BUT after I hit “Use remote source” to return to the main screen, and when try to expand the remote source itself (to select individual subfolders), I get “An error occurred” Unhandled exception in webserver request to /api/v1/filesystem... with the following detail:
# Exception
    System.Exception: Failed to process the path: Could not find a part of the path '\\?\X:\dupl-smb-efhcln6h'.
     ---> System.IO.DirectoryNotFoundException: Could not find a part of the path '\\?\X:\dupl-smb-efhcln6h'.
       at System.IO.Enumeration.FileSystemEnumerator`1.Init()
       at System.IO.Enumeration.FileSystemEnumerable`1..ctor(String directory, FindTransform transform, EnumerationOptions options, Boolean isNormalized)
       at System.IO.Enumeration.FileSystemEnumerableFactory.UserEntries(String directory, String expression, EnumerationOptions options)
       at System.IO.Directory.InternalEnumeratePaths(String path, String searchPattern, SearchTarget searchTarget, EnumerationOptions enumerationOptions)
       at Duplicati.Library.Common.IO.SystemIOWindows.EnumerateFileSystemEntries(String path)
       at Duplicati.WebserverCore.Endpoints.V1.Filesystem.ListFolderAsNodes(String entrypath, Boolean skipFiles, Boolean showHidden)+MoveNext()
       at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
       at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source)
       at Duplicati.WebserverCore.Endpoints.V1.Filesystem.Execute(String path, Boolean onlyFolders, Boolean showHidden)
       at lambda_method255(Closure, EndpointFilterInvocationContext)
       at Duplicati.WebserverCore.Middlewares.HostnameFilter.InvokeAsync(EndpointFilterInvocationContext context, EndpointFilterDelegate next)
       at Duplicati.WebserverCore.Middlewares.LanguageFilter.InvokeAsync(EndpointFilterInvocationContext context, EndpointFilterDelegate next)
       at Microsoft.AspNetCore.Http.RequestDelegateFactory.<ExecuteValueTaskOfObject>g__ExecuteAwaited|130_0(ValueTask`1 valueTask, HttpContext httpContext, JsonTypeInfo`1 jsonTypeInfo)
       at Microsoft.AspNetCore.Http.RequestDelegateFactory.<>c__DisplayClass102_2.<<HandleRequestBodyAndCompileRequestDelegateForJson>b__2>d.MoveNext()
       at Duplicati.WebserverCore.Middlewares.WebsocketExtensions.<>c__DisplayClass0_0.<<UseNotifications>b__0>d.MoveNext()
       at Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddlewareImpl.<Invoke>g__Awaited|10_0(ExceptionHandlerMiddlewareImpl middleware, HttpContext context, Task task)
# Message
I also have a second error logged, Cannot find any MS SQL Server instance. MS SQL Server is probably not installed.... but I believe that that is not related.
Therefore, I am not able to resume the previous backup. Any suggestions are much appreciated, and I am happy to provide more detail! Thanks!
Follow up - the backup job currently fails in the original configuration, as it cannot find the mapped network drive/source files. While the “Dynamic mapped pre/post script drive” (from @JonMikelV) is a successful workaround, I think there may still be issues leading to the exception above, where the SMB/UNC path mapping may be broken.
This persists in 2.4.0.1_stable_2026-10-07. Any help is much appreciated!
That is a bug in 2.4 (and 2.4.0.1). It has been fixed in canary 2.4.0.104 and will be part of a later stable release.
The error just affects the browse tree, it does not break backups.
Yes, that is just a probe to see if MSSQL is installed and should be shown in the tree.
Is this just the browsing or also the backup that fails? I tested a backup with 2.4.0.104 having a mounted SMB path and it worked without issues.
Thank you for confirming the bug. Looking forward to its rollout in a later stable release.
Just the browsing. The backup is currently using the mapped network drive as a source, not an SMB path. Therefore, it works after implementing the workaround noted above. I was trying to convert the mapped drive to a direct SMB reference as a source. Once the bug is fixed, I should be able to make the conversion and test whether the SMB-sourced backup works.
Thanks! I will mark the above as a solution for now.
