Hello,
I’m new to duplicati and wanted to use it in order to backup my docker volumes.
I’v attached my named volume I want to backup and a backup target to my duplicati-docker container (the source as read only).
Unfortunately everytime after a backup, I get the following three error messages in the log:
I the live log I get the following error message:
{"ClassName":"System.IO.IOException","Message":"Win32 IO returned 50. Path: /backup-nas/srv-docker01/dockervolumes/minecraft-server_skyblock-data/duplicati-bba31c99ea8e9447fbddefc0771987ca3.dblock.zip","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" at Duplicati.Library.Main.BackendManager.GetForTesting (System.String remotename, System.Int64 size, System.String hash) [0x00065] in <e60bc008dd1b454d861cfacbdd3760b9>:0 \n at Duplicati.Library.Main.Operation.TestHandler.DoRun (System.Int64 samples, Duplicati.Library.Main.Database.LocalTestDatabase db, Duplicati.Library.Main.BackendManager backend) [0x0042f] in <e60bc008dd1b454d861cfacbdd3760b9>:0 ","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":null,"HResult":-2147024846,"Source":"Duplicati.Library.Main"}
I’ve already tried altering the block sice from 50MB to even 10GB to get everything into one block and down to 25MB to get more blocks, but still, same issue.
I’m a little bit frustrated since I had other problems along the way and want it to work so badly since it seems to be an awesome solution (if it works).
Thank you in advance!
Benedict
heres the “Verifications” part of the log, I guess thats where the issue originates from. I just cant interprete it:
"Verifications": [
"Key": "duplicati-20220216T142149Z.dlist.zip",
"Value": [
"Key": "Error",
"Value": "Win32 IO returned 50. Path: /backup-nas/srv-docker01/dockervolumes/minecraft-server_skyblock-data/duplicati-20220216T142149Z.dlist.zip"
"Key": "duplicati-i10d68eff75ce467ea63814bdfdd82120.dindex.zip",
"Value": [
"Key": "Error",
"Value": "Win32 IO returned 50. Path: /backup-nas/srv-docker01/dockervolumes/minecraft-server_skyblock-data/duplicati-i10d68eff75ce467ea63814bdfdd82120.dindex.zip"
"Key": "duplicati-b944ae8e2353e457ea19972e61dc42d83.dblock.zip",
"Value": [
"Key": "Error",
"Value": "Win32 IO returned 50. Path: /backup-nas/srv-docker01/dockervolumes/minecraft-server_skyblock-data/duplicati-b944ae8e2353e457ea19972e61dc42d83.dblock.zip"
