HI,
It’s showing green on the home page but under logs I’m seeing the following issues:
Request for http://localhost:8200/api/v1/remoteoperation/test gave error
System.Exception: 401 - bad_auth_token: Invalid authorization token
at Duplicati.Library.Backend.Backblaze.B2AuthHelper.AttemptParseAndThrowException (System.Exception ex) <0x41d4a2c0 + 0x0058b> in <filename unknown>:0
at Duplicati.Library.Backend.Backblaze.B2AuthHelper.get_Config () <0x41cc62c0 + 0x00a2f> in <filename unknown>:0
at Duplicati.Library.Backend.Backblaze.B2AuthHelper.get_APIUrl () <0x41cc6290 + 0x0000f> in <filename unknown>:0
at Duplicati.Library.Backend.Backblaze.B2.List () <0x41cc5a30 + 0x000ab> in <filename unknown>:0
at Duplicati.Library.Backend.Backblaze.B2.Test () <0x41cc59e0 + 0x0000f> in <filename unknown>:0
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.TestConnection (System.String url, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) <0x41cc2f00 + 0x003dc> in <filename unknown>:0
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.POST (System.String key, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) <0x41cc2c30 + 0x001e7> in <filename unknown>:0
at Duplicati.Server.WebServer.RESTHandler.DoProcess (Duplicati.Server.WebServer.RESTMethods.RequestInfo info, System.String method, System.String module, System.String key) <0x41bdf270 + 0x00fec> in <filename unknown>:0
Also
**Reporting error gave error**
System.ObjectDisposedException: Cannot write to a closed TextWriter.
at System.IO.StreamWriter.Flush (Boolean flushStream, Boolean flushEncoder) <0x41a562d0 + 0x0004f> in <filename unknown>:0
at System.IO.StreamWriter.Flush () <0x41b22ab0 + 0x00031> in <filename unknown>:0
at Duplicati.Server.WebServer.RESTHandler.DoProcess (Duplicati.Server.WebServer.RESTMethods.RequestInfo info, System.String method, System.String module, System.String key) <0x41bdf270 + 0x0189e> in <filename unknown>:0
And
**Failed while executing "Backup" with id: 2**
System.Exception: 500 - internal_error: Unexpected exception
at Duplicati.Library.Main.Operation.BackupHandler.HandleFilesystemEntry (ISnapshotService snapshot, Duplicati.Library.Main.BackendManager backend, System.String path, FileAttributes attributes) <0x41d2af80 + 0x01fff> in <filename unknown>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunMainOperation (ISnapshotService snapshot, Duplicati.Library.Main.BackendManager backend) <0x41d2a5e0 + 0x00647> in <filename unknown>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, IFilter filter) <0x41cf4710 + 0x0182f> in <filename unknown>:0
Thanks.
David
