I have a couple of warnings and a couple of errors that pop up on two of my backups. They are shown even those those backups claim to have finished “successfully”. I would like to make sure that what I’m seeing is not serious, or at least doesn’t affect the stability of the backup.
First, the WARNING. I’m pretty sure its innocuous becuase there’s something about empty metadata rather than some file? In any case, the following is an example of the type of warning I’m seeing:
Nov 27, 2019 12:02 AM: Result
DeletedFiles: 1
DeletedFolders: 0
ModifiedFiles: 1
ExaminedFiles: 36027
OpenedFiles: 12
AddedFiles: 11
SizeOfModifiedFiles: 103710
SizeOfAddedFiles: 982714
SizeOfExaminedFiles: 20194206331
SizeOfOpenedFiles: 1086424
NotProcessedFiles: 0
AddedFolders: 0
TooLargeFiles: 0
FilesWithError: 0
ModifiedFolders: 0
ModifiedSymlinks: 0
AddedSymlinks: 0
DeletedSymlinks: 0
PartialBackup: False
Dryrun: False
MainOperation: Backup
CompactResults:
DeletedFileCount: 2
DownloadedFileCount: 0
UploadedFileCount: 0
DeletedFileSize: 1914
DownloadedFileSize: 0
UploadedFileSize: 0
Dryrun: False
MainOperation: Compact
ParsedResult: Warning
Version: 2.0.4.5 (2.0.4.5_beta_2018-11-28)
EndTime: 11/27/2019 12:01:21 AM (1574830881)
BeginTime: 11/27/2019 12:01:18 AM (1574830878)
Duration: 00:00:02.9266682
Messages: [
2019-11-27 00:00:00 -05 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started,
2019-11-27 00:00:09 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: (),
2019-11-27 00:00:27 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (717 bytes),
2019-11-27 00:01:03 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b4b659c409149408ab68b093bfc360440.dblock.zip.aes (667.76 KB),
2019-11-27 00:01:07 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b4b659c409149408ab68b093bfc360440.dblock.zip.aes (667.76 KB),
Warnings: [
2019-11-27 00:00:55 -05 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataGenerator.Metadata-MetadataProcessFailed]: Failed to process metadata for "<<...>>\Documents\BookSmartData\kris birthday book\library\1ea72ce3-548a-4a82-91ac-2cc596a19988.original", storing empty metadata,
2019-11-27 00:00:55 -05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: <<...>>\Documents\BookSmartData\kris birthday book\library\1ea72ce3-548a-4a82-91ac-2cc596a19988.original
While the following is the type of error I’m seeing.
DeletedFiles: 0
DeletedFolders: 0
ModifiedFiles: 0
ExaminedFiles: 61044
OpenedFiles: 0
AddedFiles: 0
SizeOfModifiedFiles: 0
SizeOfAddedFiles: 0
SizeOfExaminedFiles: 191264017084
SizeOfOpenedFiles: 0
AddedFolders: 0
TooLargeFiles: 0
FilesWithError: 0
ModifiedFolders: 0
ModifiedSymlinks: 0
AddedSymlinks: 0
DeletedSymlinks: 0
Dryrun: False
CompactResults: null
DeleteResults:
DeletedSets: []
Dryrun: False
MainOperation: Delete
ParsedResult: Error
EndTime: 12/1/2019 2:03:26 AM (1575183806)
BeginTime: 12/1/2019 2:03:09 AM (1575183789)
Duration: 00:00:16.6621065
Messages: [
2019-12-01 02:00:00 -05 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started,
2019-12-01 02:00:10 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: (),
2019-12-01 02:02:16 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (13.27 KB),
2019-12-01 02:03:09 -05 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-StartCheck]: Start checking if backups can be removed,
2019-12-01 02:03:09 -05 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-FramesAndIntervals]: Time frames and intervals pairs: 7.00:00:00 / 1.00:00:00, 28.00:00:00 / 7.00:00:00, 365.00:00:00 / 31.00:00:00,
Warnings: []
Errors: [
2019-12-01 02:06:33 -05 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-20190616T070000Z.dlist.zip.aes,
2019-12-01 02:07:51 -05 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-20190804T070002Z.dlist.zip.aes,
2019-12-01 02:09:10 -05 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-20190908T070000Z.dlist.zip.aes,
2019-12-01 02:10:31 -05 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-20191103T070003Z.dlist.zip.aes,
2019-12-01 02:11:50 -05 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-20191124T070000Z.dlist.zip.aes,
BackendStatistics:
RemoteCalls: 72
BytesUploaded: 0
BytesDownloaded: 790723838
FilesUploaded: 0
FilesDownloaded: 70
FilesDeleted: 0
FoldersCreated: 0
RetryAttempts: 24
UnknownFileSize: 0
UnknownFileCount: 0
KnownFileCount: 13584
KnownFileSize: 177480612080
LastBackupDate: 11/24/2019 2:00:00 AM (1574578800)
BackupListCount: 6
TotalQuotaSpace: 1104880336896
FreeQuotaSpace: 833139431124
AssignedQuotaSpace: -1
ReportedQuotaError: False
ReportedQuotaWarning: False
ParsedResult: Error
Messages: [
Warnings: []
Errors: [
RepairResults: null
TestResults:
MainOperation: Test
Verifications: [
Key: duplicati-20190616T070000Z.dlist.zip.aes
Value: [
Key: Error
Value: Hash mismatch on file "%TEMP%\dup-7d8fcbf4-3aad-4a98-9a43-85b1fc010b0f", recorded hash: UoGtUcOHV9AXWupkOzUW1p+ghPDVwPcq/3ylOu2uBO0=, actual hash L7dD/9ZL9HfT+SXIB22ixOIih1WpEh95+Xom012Y0F4=
Key: duplicati-20190804T070002Z.dlist.zip.aes
Value: [
Key: Error
Value: Hash mismatch on file "%TEMP%\dup-f7cb2c4e-90b9-41bf-8eaf-e336f85eddba", recorded hash: UUo6mknmU5uMn9KY3hRT6FkvYkGwPmuKyMJpY7fPEMs=, actual hash xGfSoVH/OBMJcgdBxeuKr1Udy2BzPjoMFXQLi8FqHSg=
Key: duplicati-20190908T070000Z.dlist.zip.aes
Value: [
Key: Error
Value: Hash mismatch on file "%TEMP%\dup-549d286e-1591-42c5-98a2-bd402ea2775b", recorded hash: Tblpj6iv2w4ddt+dUP56mkxB66KN4fm2bd7siFlgD1E=, actual hash ikkUhmd/3akqqGDc5uJXCqweoFwEeIW4dQqSaMeo9Qw=
Key: duplicati-20191103T070003Z.dlist.zip.aes
Value: [
Key: Error
Value: Hash mismatch on file "%TEMP%\dup-2da56840-61de-4dda-854a-fc216f78803d", recorded hash: OCDN3y9ZDpAwpXkqUdU2DTpZKEY3ScmQsmN7GrX/wsA=, actual hash S3atQ8MOQgRChlU5rl288KDbyYbPIEI93D9OgjeBlNI=
Key: duplicati-20191124T070000Z.dlist.zip.aes
Value: [
Key: Error
Value: Hash mismatch on file "%TEMP%\dup-a0da7821-8703-4b24-a803-982674c0df39", recorded hash: f8BPkSosFGEvr7fF+awqkmvTWx4UoVJqv9x7rdhTr8c=, actual hash y/qye18BuEX+KE0+cp6nzGR0L7JulbAT+2Xs+nvIu3c=
ParsedResult: Error
EndTime: 12/1/2019 2:25:49 AM (1575185149)
BeginTime: 12/1/2019 2:05:15 AM (1575183915)
Duration: 00:20:34.5288014
Messages: [
Warnings: []
Errors: [
ParsedResult: Error
EndTime: 12/1/2019 2:25:51 AM (1575185151)
BeginTime: 12/1/2019 2:00:00 AM (1575183600)
Duration: 00:25:51.1571890
Messages: [
Warnings: []
Errors: [
It seems related to Error Message following successful backup job, or Database error backup or Errors on backup but they don’t seem to shed any light.
This is a backup to OneDrive. Should I be worried?
