Hi I get the following error when I try to upgrade to 2.0.4.10_canary_2018-12-29.
System.Net.WebException: Navnet på fjernenheden kunne ikke fortolkes.: ‘alt.updates.duplicati.com’
ved Duplicati.Library.Utility.AsyncHttpRequest.AsyncWrapper.GetResponseOrStream()
ved Duplicati.Library.Utility.AsyncHttpRequest.GetResponse()
ved Duplicati.Library.AutoUpdater.UpdaterManager.DownloadAndUnpackUpdate(UpdateInfo version, Action`1 progress)
Is this still happening? Such update issues are often on the update server end. It works better for me today:
C:\Program Files\Duplicati 2>Duplicati.Library.AutoUpdater.exe check
Error detected: System.Net.WebException: The server committed a protocol violation. Section=ResponseStatusLine
at System.Net.WebClient.DownloadFile(Uri address, String fileName)
at Duplicati.Library.AutoUpdater.UpdaterManager.CheckForUpdate(ReleaseType channel)
Error detected: System.Net.WebException: The remote name could not be resolved: 'alt.updates.duplicati.com'
No updates found
New version is available: 2.0.4.12_canary_2019-01-16
