**System was rebooted and duplicati didn’t auto-run for whatever reason. Now that I have launched duplicati, I’ve noticed I haven’t had a good backup in quite some time. I’m receiving this error message each time.
[Error-Duplicati.Library.Main.Controller-FailedOperation]: The operation Backup has failed\r\nSqliteException: SQLite Error 1: ‘too many SQL variables’."
I tried updating to the newest canary build, but not luck. Is there anything in particular I can check to see why I’m receiving this message?**
Hi @Kingme024 , welcome to the forum
Can you try to look in “About Duplicati” → “Logs” and see if you can get a longer error message?
There should be an error logged with a full stack trace that we can use to figure out where the error occurs specifically, and hopefully then reproduce+fix the issue.
Hello,
Here is the most recent error:
Microsoft.Data.Sqlite.SqliteException (0x80004005): SQLite Error 1: ‘too many SQL variables’.
at Microsoft.Data.Sqlite.SqliteException.ThrowExceptionForRC(Int32 rc, sqlite3 db)
at Microsoft.Data.Sqlite.SqliteCommand.PrepareAndEnumerateStatements()+MoveNext()
at Microsoft.Data.Sqlite.SqliteCommand.GetStatements()+MoveNext()
at Microsoft.Data.Sqlite.SqliteDataReader.NextResult()
at System.Data.Common.DbCommand.ExecuteNonQueryAsync(CancellationToken cancellationToken)
— End of stack trace from previous location —
at Duplicati.Library.Main.Database.LocalDatabase.RemoveRemoteVolumes(IEnumerable1 names, CancellationToken token) at Duplicati.Library.Main.Database.LocalDatabase.RemoveRemoteVolumes(IEnumerable1 names, CancellationToken token)
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis(IBackendManager backendManager, Options options, LocalDatabase database, IBackendWriter log, IEnumerable1 protectedFiles, IEnumerable1 strictExcemptFiles, VerifyMode verifyMode, CancellationToken cancellationToken)
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList(IBackendManager backend, Options options, LocalDatabase database, IBackendWriter log, IEnumerable1 protectedFiles, IEnumerable1 strictExcemptFiles, Boolean logErrors, VerifyMode verifyMode, CancellationToken cancellationToken)
at Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify(Options options, BackupResults result, IBackendManager backendManager)
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync(String sources, IBackendManager backendManager, IFilter filter)
at Duplicati.Library.Main.Controller.<>c__DisplayClass22_0.<b__0>d.MoveNext()
at Duplicati.Library.Main.Controller.RunAction[T](T result, String & paths, IFilter& filter, Func`3 method)
at Duplicati.Library.Main.Controller.Backup(String inputsources, IFilter filter)
Feb 8, 2026, 12:08:47 AM
Thank you
Kingme024:
Thanks for reporting the stack trace!
I have now found and fixed the issue:
master ← feature/fix-large-volume-inputs
opened 12:35PM - 11 Feb 26 UTC
When performing queries with large inputs, there is a possibility that we reach … the maximum number of possible parameters. If the query exceeds the maximum number of parameters the query fails.
This change uses a temporary table that will be created in the case the inputs exceed the total number available parameters, making sure the calls proceed as before with small inputs, but uses temporary tables on larger inputs.
Some tests were added to ensure the update works as expected, even with large inputs.
This will be included in the next canary build.
