I am not able to back up my files in Onedrive Bussines, it only does one part and then it shows error, I have unlimited space in the account: Below is the duplicati log.
1 de Jul de 2018 às 05:20: Failed while executing “Backup” with id: 2
Hello @Elton_pereira_leite, welcome to the forum!
It’s good that you found the log, but we’ll need a little more detail such as what version of Duplicati you are using and what you see if you click on the ‘Failed while executing “Backup” with id: 2’ line.
For example:
Note that you can just copy / paste the TEXT of the error (rather than a screen shot) between two lines of “~~~” and it will look something like this):
Jun 23, 2018 11:18 PM: Failed while executing "Backup" with id: 9
System.IO.IOException: The source folder C:\Testfiles\ does not exist, aborting backup
at Duplicati.Library.Main.Controller.ExpandInputSources(String[] inputsources, IFilter filter)
