Hello
New user here, on Kubuntu 19.04 running Duplicati 2.0.4.23_beta_2019-07-14
I am running a learning test with one file which I have successfully set up as an encrypted backup to an S3 bucket - and successfully restored.
but I get error message at each operation: WARNING on 3 files during backup (one for each .aes file); and ERROR 1 during restore
I’d like to understand if I’ve done something wrong, or something in config which is failing, or something else?
maybe similar to the discussion here
Appreciate any guidance here
Many Thanks
Log output:
Backup log:
DeletedFiles: 0
DeletedFolders: 0
ModifiedFiles: 0
ExaminedFiles: 1
OpenedFiles: 0
AddedFiles: 0
SizeOfModifiedFiles: 0
SizeOfAddedFiles: 0
SizeOfExaminedFiles: 26321
SizeOfOpenedFiles: 0
NotProcessedFiles: 0
AddedFolders: 0
TooLargeFiles: 0
FilesWithError: 0
ModifiedFolders: 0
ModifiedSymlinks: 0
AddedSymlinks: 0
DeletedSymlinks: 0
PartialBackup: False
Dryrun: False
MainOperation: Backup
CompactResults: null
DeleteResults: null
RepairResults: null
TestResults:
MainOperation: Test
Verifications: [
Key: duplicati-20190927T060448Z.dlist.zip.aes
Value: [
Key: Error
Value: The operation is not valid for the object's storage class
Key: duplicati-i0044a32a48f24fc9a9a50c66741ec03d.dindex.zip.aes
Value: [
Key: Error
Key: duplicati-be8ab781871394813a05d5984f0588e3c.dblock.zip.aes
Value: [
Key: Error
ParsedResult: Error
Version: 2.0.4.23 (2.0.4.23_beta_2019-07-14)
EndTime: 28/09/2019 13:02:01 (1569672121)
BeginTime: 28/09/2019 13:00:00 (1569672000)
Duration: 00:02:01.0351480
Messages: [
2019-09-28 13:00:00 +01 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started,
2019-09-28 13:00:00 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: (),
2019-09-28 13:00:00 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (4 bytes),
Warnings: []
Errors: [
2019-09-28 13:00:41 +01 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-20190927T060448Z.dlist.zip.aes,
2019-09-28 13:01:21 +01 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-i0044a32a48f24fc9a9a50c66741ec03d.dindex.zip.aes,
2019-09-28 13:02:01 +01 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-be8ab781871394813a05d5984f0588e3c.dblock.zip.aes
BackendStatistics:
RemoteCalls: 17
BytesUploaded: 0
BytesDownloaded: 0
FilesUploaded: 0
FilesDownloaded: 0
FilesDeleted: 0
FoldersCreated: 0
RetryAttempts: 12
UnknownFileSize: 0
UnknownFileCount: 1
KnownFileCount: 3
KnownFileSize: 29111
LastBackupDate: 27/09/2019 07:04:48 (1569564288)
BackupListCount: 1
TotalQuotaSpace: 0
FreeQuotaSpace: 0
AssignedQuotaSpace: -1
ReportedQuotaError: False
ReportedQuotaWarning: False
ParsedResult: Error
Messages: [
Warnings: []
Errors: [
ParsedResult: Error
Duration: 00:02:01.7362870
Messages: [
Warnings: []
Errors: [
Restore log:
FilesRestored: 1
SizeOfRestoredFiles: 26321
FoldersRestored: 0
SymlinksRestored: 0
FilesPatched: 0
FilesDeleted: 0
FoldersDeleted: 0
SymlinksDeleted: 0
MainOperation: Restore
RecreateDatabaseResults: null
ParsedResult: Error
EndTime: 30/09/2019 10:00:30 (1569834030)
BeginTime: 30/09/2019 09:59:49 (1569833989)
Duration: 00:00:40.8101280
Messages: [
2019-09-30 09:59:49 +01 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Restore has started,
2019-09-30 09:59:49 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: (),
2019-09-30 09:59:49 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (4 bytes),
2019-09-30 09:59:49 +01 - [Information-Duplicati.Library.Main.Database.LocalRestoreDatabase-SearchingBackup]: Searching backup 0 (27/09/2019 06:04:48) ...,
2019-09-30 09:59:49 +01 - [Information-Duplicati.Library.Main.Operation.RestoreHandler-RemoteFileCount]: 1 remote files are required to restore,
Warnings: []
Errors: [
2019-09-30 10:00:30 +01 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-PatchingFailed]: Failed to patch with remote file: "duplicati-be8ab781871394813a05d5984f0588e3c.dblock.zip.aes", message: The operation is not valid for the object's storage class
BackendStatistics:
RemoteCalls: 6
BytesUploaded: 0
BytesDownloaded: 0
FilesUploaded: 0
FilesDownloaded: 0
FilesDeleted: 0
FoldersCreated: 0
RetryAttempts: 4
UnknownFileSize: 0
UnknownFileCount: 1
KnownFileCount: 3
BackupListCount: 1
TotalQuotaSpace: 0
FreeQuotaSpace: 0
ParsedResult: Error
Messages: [
Warnings: []
Errors: [
