Duplicati went well for a couple of weeks. The last 2 updates broke my 2 running backups. The last one has done it for me completely. How to fix this?
Error: NameResolutionFailure
Fatal error
System.Net.WebException: Error: NameResolutionFailure
at System.Net.WebConnection+<Connect>d__16.MoveNext () [0x00044] in <fc308f916aec4e4283e0c1d4b761760a>:0
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <71d8ad678db34313b7f718a414dfcb25>:0
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <71d8ad678db34313b7f718a414dfcb25>:0
at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <71d8ad678db34313b7f718a414dfcb25>:0
at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <71d8ad678db34313b7f718a414dfcb25>:0
at System.Net.WebConnection+<InitConnection>d__19.MoveNext () [0x000cc] in <fc308f916aec4e4283e0c1d4b761760a>:0
at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <71d8ad678db34313b7f718a414dfcb25>:0
at System.Net.WebOperation+<Run>d__57.MoveNext () [0x0009a] in <fc308f916aec4e4283e0c1d4b761760a>:0
at System.Net.WebCompletionSource`1+<WaitForCompletion>d__15[T].MoveNext () [0x00094] in <fc308f916aec4e4283e0c1d4b761760a>:0
at System.Net.HttpWebRequest+<RunWithTimeoutWorker>d__244`1[T].MoveNext () [0x000ba] in <fc308f916aec4e4283e0c1d4b761760a>:0
at Duplicati.Library.Main.BackendManager.List () [0x00049] in <ae134c5a9abb455eb7f06c134d211773>:0
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.String protectedfile) [0x0000d] in <ae134c5a9abb455eb7f06c134d211773>:0
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.String protectedfile) [0x00000] in <ae134c5a9abb455eb7f06c134d211773>:0
at Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify (Duplicati.Library.Main.BackendManager backend, System.String protectedfile) [0x000fd] in <ae134c5a9abb455eb7f06c134d211773>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter) [0x003c6] in <ae134c5a9abb455eb7f06c134d211773>:10
It would help if we know what version of Dupliati you are running and on what OS (Linux, MacOS, Windows) - but usually that NameResolutionFailure error happens on Linux/MacOS so I’m going to assume you’re using one of those for now. (Here are some similar issues mentioned by other users Search results for ‘NameResolutionFailure’ - Duplicati).
Can you try running ping localhost in a terminal window? You should see something like “Reply from…” repeated a number of times (you can use ctrl-c to stop it).
If you DON’T get a “Reply from…” response, then you mist likely need to add 127.0.0.1 localhost to your /etc/hosts file.
Of course you had Duplicati running fine for a while so unless something else has removed localhost from your hosts file I’m not sure why this would have started happening, so please let us know whether or not this helps you out.
(By the way, I edited your original post by adding “~~~” before and after the error message to make it easier to read.)
I’m seeing this now - had no problem like this with the version I’m running until today, and “ping localhost” returns 127.0.0.1 just fine… it happens after the “verifying backend” has been showing on the top of the web ui for a few minutes. The backend is B2 backblaze.
This is in Fedora 30, version 2.0.4.21_experimental_2019-06-28. And restarting the service doesn’t break anything - it comes up fine.
My router has been up for 9 days w/o incident and I don’t see any errors there regarding dns-related problems. Restarting the duplicati service doesn’t cause any immediate error, but it doesn’t fix things either. Still get something similar to the error logged above, with unfortunately no indication of what hostname lookup is failing.
Here’s the log entry:
at System.Net.WebConnection.Connect (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x00079] in <cae6d5d40bdb48e7919fce5039029dd1>:0
at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x000f7] in <cae6d5d40bdb48e7919fce5039029dd1>:0
at System.Net.WebOperation.Run () [0x000b7] in <cae6d5d40bdb48e7919fce5039029dd1>:0
at System.Net.WebCompletionSource`1[T].WaitForCompletion () [0x000b1] in <cae6d5d40bdb48e7919fce5039029dd1>:0
at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x00118] in <cae6d5d40bdb48e7919fce5039029dd1>:0
at Duplicati.Library.Main.BackendManager.List () [0x00049] in <0f9596a4606a4cc196eb7582e49cc580>:0
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.String protectedfile) [0x0000d] in <0f9596a4606a4cc196eb7582e49cc580>:0
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.String protectedfile) [0x00000] in <0f9596a4606a4cc196eb7582e49cc580>:0
at Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify (Duplicati.Library.Main.BackendManager backend, System.String protectedfile) [0x0010d] in <0f9596a4606a4cc196eb7582e49cc580>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter) [0x0103a] in <0f9596a4606a4cc196eb7582e49cc580>:0
at CoCoL.ChannelExtensions.WaitForTaskOrThrow (System.Threading.Tasks.Task task) [0x00050] in <6973ce2780de4b28aaa2c5ffc59993b1>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter) [0x00008] in <0f9596a4606a4cc196eb7582e49cc580>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass13_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x00035] in <0f9596a4606a4cc196eb7582e49cc580>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x00271] in <0f9596a4606a4cc196eb7582e49cc580>:0
at Duplicati.Library.Main.Controller.Backup (System.String[] inputsources, Duplicati.Library.Utility.IFilter filter) [0x00068] in <0f9596a4606a4cc196eb7582e49cc580>:0
at Duplicati.Server.Runner.Run (Duplicati.Server.Runner+IRunnerData data, System.Boolean fromQueue) [0x002f7] in <5ee414afc7e943419837effe11774b4a>:0
I’m using a relatively recent version, and it only just started failing today, having changed nothing else that I can see that would be related to the failure… so not sure this should be closed.
Or maybe I should open another thread?
Or maybe I just had to wait a few more hours… as the problem is now gone and my backup is working again. Hmmm. Not a satisfying fix.
