I am having this same issue also. This is hand in hand with the same error when trying to run my backup job. I am running on an Asustor NAS. I was going to try and uninstall and reinstall Mono as I understand it has something to do with this, but obviously it tries then wants to uninstall Duplicati
Any help would be appreciated as the only option at the minute is to select accept-any-ssl-certificate.
I have tried running sudo /usr/local/AppCentral/mono/bin/cert-syn
c /etc/ssl/certs/ca-certificates.crt
which works but the update nor the backup works. It has been like this since 30th November
This is the error from running the backup job
{“ClassName”:“System.Net.WebException”,“Message”:“Error: TrustFailure (Authentication failed, see inner exception.)”,“Data”:null,“InnerException”:{“ClassName”:“System.Security.Authentication.AuthenticationException”,“Message”:“Authentication failed, see inner exception.”,“Data”:null,“InnerException”:{“Message”:“Ssl error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED\n at /asustor/trunk_2021_01_12/x64_g3/x64_g3/objs/mono-6.12.0.107/external/boringssl/ssl/handshake_client.c:1132”,“Data”:{},“InnerException”:null,“StackTrace”:" at Mono.Btls.MonoBtlsContext.ProcessHandshake () [0x00048] in <652d36f38550428c85c9b233c47d70a6>:0 \n at Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake (Mono.Net.Security.AsyncOperationStatus status, System.Boolean renegotiate) [0x000da] in <652d36f38550428c85c9b233c47d70a6>:0 \n at (wrapper remoting-invoke-with-check) Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake(Mono.Net.Security.AsyncOperationStatus,bool)\n at Mono.Net.Security.AsyncHandshakeRequest.Run (Mono.Net.Security.AsyncOperationStatus status) [0x00006] in <652d36f38550428c85c9b233c47d70a6>:0 \n at Mono.Net.Security.AsyncProtocolRequest.ProcessOperation (System.Threading.CancellationToken cancellationToken) [0x000fc] in <652d36f38550428c85c9b233c47d70a6>:0 “,“HelpLink”:null,“Source”:“System”,“HResult”:-2146233088},“HelpURL”:null,“StackTraceString”:” at Mono.Net.Security.MobileAuthenticatedStream.ProcessAuthentication (System.Boolean runSynchronously, Mono.Net.Security.MonoSslAuthenticationOptions options, System.Threading.CancellationToken cancellationToken) [0x00262] in <652d36f38550428c85c9b233c47d70a6>:0 \n at Mono.Net.Security.MonoTlsStream.CreateStream (System.Net.WebConnectionTunnel tunnel, System.Threading.CancellationToken cancellationToken) [0x0016a] in <652d36f38550428c85c9b233c47d70a6>:0 \n at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x001ba] in <652d36f38550428c85c9b233c47d70a6>:0 “,“RemoteStackTraceString”:null,“RemoteStackIndex”:0,“ExceptionMethod”:null,“HResult”:-2146233087,“Source”:“mscorlib”},“HelpURL”:null,“StackTraceString”:” at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x0021a] in <652d36f38550428c85c9b233c47d70a6>:0 \n at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x00141] in <652d36f38550428c85c9b233c47d70a6>:0 \n at System.Net.WebOperation.Run () [0x0009a] in <652d36f38550428c85c9b233c47d70a6>:0 \n at System.Net.WebCompletionSource1[T].WaitForCompletion () [0x00094] in <652d36f38550428c85c9b233c47d70a6>:0 \n at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in <652d36f38550428c85c9b233c47d70a6>:0 \n at Duplicati.Library.Utility.AsyncHttpRequest+AsyncWrapper.GetResponseOrStream () [0x0004d] in <2a3ee711c7c04f6c957360f2cf183a7f>:0 \n at Duplicati.Library.Utility.AsyncHttpRequest.GetResponse () [0x00044] in <2a3ee711c7c04f6c957360f2cf183a7f>:0 \n at Duplicati.Library.Backend.Backblaze.B2AuthHelper.get_Config () [0x0013d] in :0 \n at Duplicati.Library.Backend.Backblaze.B2AuthHelper.get_APIUrl () [0x00000] in :0 \n at Duplicati.Library.Backend.Backblaze.B2.List () [0x00011] in :0 \n at Duplicati.Library.Main.BackendManager.DoList (Duplicati.Library.Main.BackendManager+FileEntryItem item) [0x00011] in :0 \n at Duplicati.Library.Main.BackendManager.ThreadRun () [0x00108] in :0 ",“RemoteStackTraceString”:null,“RemoteStackIndex”:0,“ExceptionMethod”:null,“HResult”:-2146233079,“Source”:“Duplicati.Library.Utility”}
and the error running the update
System.Net.WebException: Error: TrustFailure (Authentication failed, see inner exception.) —> System.Security.Authentication.AuthenticationException: Authentication failed, see inner exception. —> Mono.Btls.MonoBtlsException: Ssl error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED
at System.Net.WebCompletionSource1[T].WaitForCompletion () [0x00094] in <652d36f38550428c85c9b233c47d70a6>:0 at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in <652d36f38550428c85c9b233c47d70a6>:0
at System.Net.HttpWebRequest.GetResponse () [0x00016] in <652d36f38550428c85c9b233c47d70a6>:0
at System.Net.WebClient.GetWebResponse (System.Net.WebRequest request) [0x00000] in <652d36f38550428c85c9b233c47d70a6>:0
at System.Net.WebClient.DownloadBits (System.Net.WebRequest request, System.IO.Stream writeStream) [0x000e6] in <652d36f38550428c85c9b233c47d70a6>:0
at System.Net.WebClient.DownloadFile (System.Uri address, System.String fileName) [0x00088] in <652d36f38550428c85c9b233c47d70a6>:0
at System.Net.WebClient.DownloadFile (System.String address, System.String fileName) [0x00008] in <652d36f38550428c85c9b233c47d70a6>:0
at (wrapper remoting-invoke-with-check) System.Net.WebClient.DownloadFile(string,string)
at Duplicati.Library.AutoUpdater.UpdaterManager.CheckForUpdate (Duplicati.Library.AutoUpdater.ReleaseType channel) [0x000ee] in <8d4cb1693e00483189d3952c3f0ed20f>:0
