I store my backups on the server. I want to delete files and reconfigure them. I am getting the following error when I unconfigure the files without deleting them
thanks! but ı get this error
The database was attempted repaired, but the repair did not complete. This database may be incomplete and the backup process cannot continue. You may delete the local database and attempt to repair it again.
There is one more problem.
This operation can not access the file because another operation has locked part of the file.
Destination and database are synchronized, not making any changes
Not sure what happens here, but the path appears to have a / in it, are you sure this is correct? AFAIK, Windows will map that to \.
Also, could it be that the user you are logging in with in Duplicati is getting another folder than what you see if you log in with your normal account?
