Error - DynamicLoader
Hello everybody,
I get the following error now for a second time after a bunch of complete backups.
What’s is all about? Do I have to worry?
That error only occurs on my backup to my local unraid server.
It doesn’t occurs on the backup to backblaze cloud.
Both backups are set up identical - only the destination (local unraid server vs. backblaze cloud) differs.
Thanks for any help
* 2020-12-21 13:43:18 +01 - [Warning-Duplicati.Library.DynamicLoader.DynamicLoader1-SoftError]: Fehler beim Laden des Prozesstyps Duplicati.Library.Common.IO.VssBackupComponents Assembly /Applications/Duplicati.app/Contents/Resources/Duplicati.Library.IO.dll, Fehlermeldung: Could not load type of field ‘Duplicati.Library.Common.IO.VssBackupComponents:_vssBackupComponents’ (1) due to: Could not load file or assembly ‘AlphaVSS.Common, Version=1.4.0.0, Culture=neutral, PublicKeyToken=959d3993561034e3’ or one of its dependencies.`
It’s a harmless bug that can be ignored. It has been fixed in newer versions but it’s not yet fixed in the beta releases. You can see more detailed discussion here (and other threads) with a manual fix:
It seems to work :slight_smile:
If I get any errors in the futere I’ll report - but for now it’s ok.
Thank you very much and have a happy holidays!!
