I’m getting the following error every time I try to run my backup:
constraint failed
UNIQUE constraint failed: Remotevolume.Name, Remotevolume.State
I have tried stopping/re-starting the duplicati service (I have it installed as a service).
I should note that if I go to the Backup Config’s Database page, and click “Repair” I get the exact same message, so it appears to be a backend database issue.
Thanks for any help. If I figure it out, I’ll post my results here.
– Andrew.
My log file has this in it
{"errorCode":"Constraint","ClassName":"System.Data.SQLite.SQLiteException","Message":"constraint failed\r\nUNIQUE constraint failed: Remotevolume.Name, Remotevolume.State","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" at System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)\r\n at System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)\r\n at System.Data.SQLite.SQLiteDataReader.NextResult()\r\n at System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCommand cmd, CommandBehavior behave)\r\n at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)\r\n at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery(CommandBehavior behavior)\r\n at Duplicati.Library.Main.Database.LocalDatabase.UpdateRemoteVolume(String name, RemoteVolumeState state, Int64 size, String hash, Boolean suppressCleanup, TimeSpan deleteGraceTime, IDbTransaction transaction)\r\n at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, String protectedfile)\r\n at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, String protectedfile)\r\n at Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify(BackendManager backend, String protectedfile)\r\n at Duplicati.Library.Main.Operation.BackupHandler.Run(String[] sources, IFilter filter)\r\n at Duplicati.Library.Main.Controller.<>c__DisplayClass16_0.<Backup>b__0(BackupResults result)\r\n at Duplicati.Library.Main.Controller.RunAction[T](T result, String[]& paths, IFilter& filter, Action`1 method)\r\n at Duplicati.Library.Main.Controller.Backup(String[] inputsources, IFilter filter)\r\n at Duplicati.Server.Runner.Run(IRunnerData data, Boolean fromQueue)","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":"8\nReset\nSystem.Data.SQLite, Version=1.0.105.2, Culture=neutral, PublicKeyToken=db937bc2d44ff139\nSystem.Data.SQLite.SQLite3\nSystem.Data.SQLite.SQLiteErrorCode Reset(System.Data.SQLite.SQLiteStatement)","HResult":-2147467259,"Source":"System.Data.SQLite","WatsonBuckets":null}
