Error connecting to Dropbox
Hi
While trying to set Dropbox as backup destination storage type, with the generated AuthID, connection test procedure encounters such an error:
Failed to connect: Non-json response: Error in call to API function "files/list_folder": The given OAuth 2 access token is malformed.
I tried so many cases, but didn’t succeed!
Any suggestions would be great…
Welcome to the forum @Hadi_Asgari
Does this mean it’s a new backup, and you have no others on Dropbox?
If you have a working Dropbox backup (or an export of it), try old AuthID.
Duplicati - Dropbox Backup - Short lived token expires supported new Dropbox need two days ago.
Possibly there’s a problem with the with the new code. There’s a parallel situation in GitHub issues:
[Dropbox oauth] expired_access_token error from Dropbox short-lived access tokens #4667
Thanks…
Yes, this is the first time and there is no working Dropbox backup yet.
So, is there anything to do, or we should just wait until the project developers work on the code?
Based on the first forum report, Dropbox doing their announced change broke new users mid-January.
Unless you wish to do some developer/network level analysis (challenging) you probably need to wait.
If you’re eager to use Dropbox in hope of future fix, you might be able to use a temporary rclone setup.
@Hadi_Asgari I have added a fix to the code, but it will be a little while before an updated version is available.
Hi Hadi_Asgari we’re also experiencing the same issue regarding the authentication process & dropbox. Great to hear you’ve worked the code. Any idea as to timescales days, weeks or months?
Thanks
The fix is ready to be deployed, but the code signing certificate has expired, so I need to purchase a new one first. That usually takes a week or so.
Any update on this? We were attempting to restore a backup and can’t set up the new system to access our backups.
No update. I am still waiting for verification before I can get a new certificate (it is always a hassle).
I can build an unsigned version and attach here if it helps?
It would be beneficial for us, if you would do that!
:smiley:
Specially if it could be deployed in Docker, somehow!
:sweat_smile:
I have put up a build here:
It is signed with GPG but not Authenticode. If you run it on Windows you can expect it to trigger Antivirus warnings. Other platforms should not give any problems.
Is there a way to utilize it on a previously made Duplicati Docker container?
For example replacing former files on the Container made using the last Duplicati Docker Image, with the new files, on:
/source/hostfiles/var/lib/docker/overlay2/49c6e8495c1685858bf8fc158a9153a564fb1b6bd98f39895df26c8bfe8399a8/diff/app/duplicati
I guess you can just extract the files and mount the /app/duplicati folder?
Otherwise, I have just updated the Docker images, so you should be able to update the image.
I pulled the new Docker Image (duplicati/duplicati:2.0.6.101_canary_2022-03-13), and deployed it on a new container, but the error exists again, while trying to test the connection to Dropbox:
I tried it again today, and here is the new error:
Failed to connect: Failed to authorize using the OAuth service: Forbidden. If the problem persists, try generating a new authid token from: https://duplicati-oauth-handler.appspot.com?type=dropbox
…After I tried more and more, sometimes it returns the above error, and other times, it just stucks on “Testing Connection…”
Even trying to test with “Google Drive”, or “Google Cloud Storage”, has same results, or after a long time it leads to “Connection Failed” message!
Am I doing anything wrong?!..
Finally! I got the a new certificate and released a signed version. Hope this helps, otherwise, DM me.
It sounds like a general connection issue.
I have released a new version that is signed and follows the normal release process. I hope this fixes the issue for you.
Does your Dropbox authid contain a colon character?
(i.e.: 1234:5678)
(i.e.: 1234:5678 )
yes, and i’m having the same @Hadi_Asgari issue on latest docker image.
Welcome to the forum @FrancYescO
While no response came here, I asked about success on the GitHub issue, and got:
I just installed 2.0.6.102 and was able to successfully run a new dropbox backup!
but I don’t know where that leaves things. Is it possible that this only fails in Docker?
If someone wants to head over to GitHub, maybe you can look for any differences…
