( Quando vou baixar o arquivo da o erro. )
ERRO: O certificado de “updates.duplicati.com” não é confiável.
ERRO: The certificate of “updates.duplicati.com” has expired.
com umas pesquisas achei essa solução… mas no meu saco não resolve -no-check-certificate
com apenas 1 - e nem com 2 – Não funciona.
wget --no-check-certificate //updates.duplicati.com/beta/duplicati_2.0.6.3-1_all.deb
Debian 8 is very old (end of life was June 2018). I’m guessing your certificate store is way out of date and doesn’t support some of the more recent CAs.
That being said, I have a Debian 8 VM and I was able to get this to work:
wget --no-check-certificate https://updates.duplicati.com/beta/duplicati_2.0.6.3-1_all.deb
You can also try downloading it from github repository, that seems to work on Debian 8 without any special parameter on wget:
wget https://github.com/duplicati/duplicati/releases/download/v2.0.6.3-2.0.6.3_beta_2021-06-17/duplicati_2.0.6.3-1_all.deb
Valeu Obrigado consegui baixar pelo github agora vou tentar instalar… Obrigado.
