Duplicati using source from file (espessicaly created by run-script-before-required)
Hello for everyone? Is it possible or not? I created this file for source but D2 writes that “parameters-file” is unknown.
May be I do something wrong? And also is it possible to create parameter file in “run-script-before-required” and use it after?
I don’t want to run D2.cli with parameters in scheduled script because I can’t see useful info from GUI (number of backups, size of it and so on). Or am I wrong too?))
Or may be where is a way to list or sources in after backup script?
It’s not clear what list type you want, but see “C:\Program Files\Duplicati 2\run-script-example.bat” or
Thank you. I don’t understand how could I miss it.
