I am new to Duplicati. I’m trying to set it up to encrypt my Nextcloud data and copy to OneDrive.
I am using linuxserver.io docker image on a Nextcloudpi image (Raspbian). I have 2 drives and I am using rsync to mirror the data via a cron job.
I have pointed Duplicati at the backup volume. Every time I run the backup I get warnings about FileAccessError. These do appear to be actual errors and not just warnings as the data is being copied since Duplicati is unable access the folder with the data.
The strange thing is that it has actually worked at least once as the volume of data backed up is similar size to the source.
I have added the non-root user running Duplicati to the group that owns the folders, I have used chmod -R ugo+rwx on the data folder and chown -R
These are the messages:
2020-02-16 23:42:15 +00 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: /source/ncdata/
2020-02-16 23:42:17 +00 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: /source/ncdata/
Please help me figure it out.
What is the easiest way to confirm which files have been backed up and when they were last updated?
Thanks in advance
Andrew
