Duplicati test found error, how to fix?
Run the test command with all parameter resulted in reported errors.
How can I fix this?
Log:
duplicati-if516d6672faf40f686f89c1ea30a286a.dindex.zip.aes: 18 errors
	Extra: /lhy5PaFVLVOGT5OtSpphmPrS9jIW1mmyHVo1eJCX4Q=
	Extra: 24bX29GSpRG5tUHdJWOccJk9Ry7TXu0OemxAEv1kwJ0=
	Extra: 7j2Qe7AvDkyiZXwZtqZ+Eh4A2QJE6s5OcgnoX9vxKYY=
	Extra: A2sHgIzuBYg1LmO3IUSdzlQ5Mfr5rPKD/b/03oFUEaU=
	Extra: BZg63xPCfp1iUvub5H4LcdRFCRQx0NUVIywNZCIu2Ns=
	Extra: DFedREaeY8yicadLK7TSWEM/wVSxwjX+phCle2GcFY4=
	Extra: HCSAsNdA0CeGgUXLwMH30Sb3B/iK8ngDEkxfP3HhDUs=
	Extra: JgceREW3rpHkYKCO5z+6rYeKfraOiKLx5pfo+ABdsnI=
	Extra: LQaGSOD0bwoJquB8SyGzc1kfQ/+NIYZKn0OQ6heltOs=
	Extra: Nm+e0vntFuWYfWGU8zHX5U+4a26r3kazT0+qhzqplm4=
	... and 8 more
duplicati-i372dd1272e20480cb4aef86bd45aace3.dindex.zip.aes: 5 errors
	Extra: 9UFNMo22DrqKDUUQLVLki8eUbCaI3eORELky43f7abc=
	Extra: PLpBpqgPfStGIktrgha5uKK3Em9RakZWhNCcz8nr1fE=
	Extra: Q0uQG0r2RrzcwG2wyLRfb+XG+qpTKuNcdJNqqCr9hKE=
	Extra: UivMIGIJNeq0R90iZK8YJC/aeSb0c91s9tUeRQAEt3M=
	Extra: k/lYffdr+MLOpmHjFUsF6dKIMdTTlkffmQ0xDome/G4=
duplicati-if084d2ca34044622be130a683ad21ae5.dindex.zip.aes: 1 errors
	Extra: /Uyf2pzT+a58lisN3zcjIpTVVYDhqhZaoGEpuFSTies=
duplicati-icd087483c33548caa791abc36286c4a7.dindex.zip.aes: 1 errors
	Extra: knjLoCTK1/NoGixHQsWiyU5Wx7feJUTdFqQdImHXKpE=
duplicati-iee2e19c3f07644cebefd597a1436ad92.dindex.zip.aes: 2 errors
	Extra: L8ofKbc91bQVn6HrFuaSdkgvUiS6fSIZpUcDkSmlHw4=
	Extra: izgzyEMiRL3xiwDnTKYJY7UL0mWcGbI7tqJ9o3FMbQI=
duplicati-i400f3ae703c24e9e9d87d12976a10670.dindex.zip.aes: 11 errors
	Extra: 0ZxmpOLdt+h1IY/8yZDS52gO5JyOmPKTNrMpduxsrV4=
	Extra: 0cYF/8cIRLqLxMXt0VRlXYVj3ugzItRExvtSCig0xdc=
	Extra: 10uSP5N/wr/hqSZoIKBTaWqyPJoSBhxtzl0sl7kXN/o=
	Extra: 2MUREDPCIQjcTNJFl3+DNl4SvlT53JCIcFLf0Ng6/is=
	Extra: JCPEZVIzWz2J3ZVBZ+w4FSsel7A8lD3bvaQGP9JXOJs=
	Extra: TLxueEAizjGu05qfLte46SsLSKd8J6ZABVl4LufDQPw=
	Extra: XEL9XZlgBWxRua80CLpDcsZhjymSxtA0spY9SyQ39l0=
	Extra: enlDJfEekgYBvc7k5MrvYG2nwZDlGherIu27JJpNzKA=
	Extra: gB0OqKNWY4zWw0iVav+0y5gKpBw0LvCELOUwQLrtQJ4=
	Extra: lRH0DzLAcc1oo/gQ5u9r6dJ2izLSsVnjVS11t2j0w30=
	... and 1 more
duplicati-b7370975a71f64db88f9d61cce146a3a4.dblock.zip.aes: 1 errors
duplicati-b1cf0c60effb44742aaa7c1976f03ce8e.dblock.zip.aes: 11 errors
	... and 1 more
duplicati-bd5833232695049f7adbcfb04b5049933.dblock.zip.aes: 2 errors
duplicati-bc4fc066c1b874ff3bc70c0b31c88b9ef.dblock.zip.aes: 5 errors
duplicati-bbd2ef0c73ab04639881bc5833243d241.dblock.zip.aes: 1 errors
duplicati-b7581a73a429747b5ae705b34d4d275d1.dblock.zip.aes: 18 errors
	... and 8 more
Return code: 3
Hi @Mikael_Andersson, welcome to the forum!
Answers to a few of these questions might help us narrow down what’s going on:
Note that according to the main developer, the “Extra:” errors may be concerning as to why they happened, but should not cause any issues with actual file restores.
I’m running macos high sierra and ubuntu 18.04. Both instances backup to Google drive and B2. Both are running 2.0.3.9.
I get the errors on all 4 backups. No other errors.
Thanks
Just to confirm, your backups themselves are running OK - it’s just when you do the file test that these “Extra:” errors are found, right?
I believe an update is being worked on that should help with those errors, but until then there’s not much that can be done other than to delete the listed dindex files and run a database Repair which should rebuild those files.
However, that’s a fairly hands-on thing to do and since the extra hashes shouldn’t cause any problems (either on backup or restore) I don’t know that it’s necessary to actually “fix” them.
If you have a retention policy that clears out older versions, those dindex files should eventually get automatically cleaned up as part of the compacting process.
I do have one concern, however, and am going to ping @kenkendk @Pectojin for their input - what are the repercussions of a database RECREATE being done against dindex files with “extra” hashes? (Keep in mind a recreate could unintentionally be triggered by changing running accounts such as switching between user and service / daemon.)
That is correct. I’ll leave it be for now.
