More information on the first of the 2 errors that show:
System.UnauthorizedAccessException: Access to the path ‘/shares/test folder’ is denied. —> System.IO.IOException: Operation not permitted — End of inner exception stack trace — at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirError) at System.IO.FileStatus.SetAccessOrWriteTimeCore(SafeFileHandle handle, String path, DateTimeOffset time, Boolean isAccessTime, Boolean checkCreationTime, Boolean asDirectory) at System.IO.Directory.SetLastWriteTimeUtc(String path, DateTime lastWriteTimeUtc) at Duplicati.Library.Common.IO.SystemIOLinux.DirectorySetLastWriteTimeUtc(String path, DateTime time) at Duplicati.Library.Main.Operation.RestoreHandler.ApplyMetadata(String path, Stream stream, Boolean restorePermissions, Boolean restoreSymlinkMetadata, Boolean dryrun) at Duplicati.Library.Main.Operation.Restore.FileProcessor.RestoreMetadata(LocalRestoreDatabase db, FileRequest file, IChannel`1 block_request, IChannel`1 block_response, Options options, Stopwatch sw_meta, Stopwatch sw_work, Stopwatch sw_req, Stopwatch sw_resp) at Duplicati.Library.Main.Operation.Restore.FileProcessor.<>c__DisplayClass2_0.<b__0>d.MoveNext() — End of stack trace from previous location — at CoCoL.AutomationExtensions.RunTask[T](T channels, Func`2 method, Boolean catchRetiredExceptions) at Duplicati.Library.Main.Operation.RestoreHandler.DoRunNewAsync(IBackendManager backendManager, LocalRestoreDatabase database, IFilter filter, CancellationToken cancellationToken) at Duplicati.Library.Main.Operation.RestoreHandler.RunAsync(String paths, IBackendManager backendManager, IFilter filter) at Duplicati.Library.Main.Controller.<>c__DisplayClass23_0.<b__0>d.MoveNext() — End of stack trace from previous location — at Duplicati.Library.Utility.Utility.Await(Task task) at Duplicati.Library.Main.Controller.RunAction[T](T result, String& paths, IFilter& filter, Func`3 method) at Duplicati.Library.Main.Controller.Restore(String paths, IFilter filter) at Duplicati.Server.Runner.RunInternal(Connection databaseConnection, EventPollNotify eventPollNotify, INotificationUpdateService notificationUpdateService, IProgressStateProviderService progressStateProviderService, IApplicationSettings applicationSettings, IRunnerData data, Boolean fromQueue) at Duplicati.Server.Runner.Run(Connection databaseConnection, EventPollNotify eventPollNotify, INotificationUpdateService notificationUpdateService, IProgressStateProviderService progressStateProviderService, IApplicationSettings applicationSettings, IQueuedTask data, Boolean fromQueue) at Duplicati.WebserverCore.Services.QueueRunnerService.RunTask(IQueuedTask task)
And the second error:
