Duplicati on centos not starting at boot
Installed duplicati-2.0.4.23-2.0.4.23_beta_20190714.noarch.rpm on CentOS 7.
It’s working properly, but doesn’t automatically starting after a restart.
Tried systemctl enable, but it doesn’t find the service file.
Any ideas ?
Thanks!
I can’t remember but I think you have to create it yourself, but in any case here’s mine for Fedora if it helps:
[Unit]
Description=Duplicati Backup software
[Service]
ExecStart=/usr/bin/mono /usr/lib/duplicati/Duplicati.Server.exe --webservice-interface=any --webservice-sslcertificatefile=/usr/share/Duplicati/maggie.pfx --webservice-sslcertificatepassword=12345
Restart=on-failure
RestartSec=30
[Install]
WantedBy=multi-user.target
The parameters change the default to listen on all interfaces and loads an SSL certificate for HTTPS support, so you can leave those two out if you want.
Thanks alot Taomyn!
That solved it!
