Hi guys,
Is it possible to install Duplicati on aarch64 GNU/Linux ?
I have NanoPi Neo2 with Linux openmediavault 4.11.2, Debian GNU/Linux 8.9 (jessie) and trying to install and run Duplicati.
No matter how I try I have always problem with mscorlib.dll
I have also posted on GitHub ( Issues with Duplicati plugin · Issue #2 · OpenMediaVault-Plugin-Developers/openmediavault-duplicati · GitHub ) but problem persist no matter if it is with openmediavault-duplicati or not.
Is there any way to run Duplicati on that platform?
Thanks.
I wrote a comment on that page.
Not sure how it works, but generally instructions for installing Duplicati is to follow:
http://mono-project.com/download#download-lin
Then use either the .deb or .zip.
For the .dep you should be able to run sudo apt-get install -f duplicati.deb and then just run duplicati or duplicati-cli.
If you use the .zip, then simply unzip the archive and run mono Duplicati.exe or mono Duplicati.CommandLine.exe.
I have already followed instructions from http://mono-project.com
I have mono installed. Its version is: 5.2.0.224-0xamarin3+debian8b1 arm64
Also ca-certificates-mono is installed in the same version.
Duplicati is 2.0.2.8-1.
When running duplicati there is:
Corlib not in sync with this runtime: expected corlib version 1050700001, found 1050200001.
Loaded from: /usr/lib/mono/4.5/mscorlib.dll
Download a newer corlib or a newer runtime at Download | Mono.
Not sure why it happens here, but there is an SO thread that mentions the same:
It also has a few workarounds that are reported as “working”
I have already read it and it does not apply to my situation. Unfortunately
