HI need info. Can a lot of versions be a problem?
I have a backup running every one hour. Now have about 582 versions. Will there be a problem when I will have a lot of versions?
Also, is it possible to stop backup creation between 20:00 and 07:00 the next day?
Thank you
More versions means Duplicati has to track more and more data about your backups. This could cause the sqlite database to get larger and make operations take longer.
I would consider automatically pruning older versions. Duplicati can support a robust retention policy that automatically reduces the number of versions the older they get. This is what I personally use:
--retention-policy="7D:U,3M:1D,2Y:1W,U:1M"
This means:
- For the most recent 7 days, keep unlimited (all) backups
- After that, for the most recent 3 months, keep 1 backup per day
- After that, for the most recent 2 years, keep 1 backup per week
- After that, for an unlimited amount of time keep 1 backup per month
You can of course adapt to your liking. The custom retention policy option can be seen on page 5 of the backup job configuration:
The built in scheduler doesn’t provide support for that. Some have been able to do it using a custom script that runs before the backup job and tells Duplicati to not run the backup if it’s outside of a certain time window. Here’s an example script for Windows: Feature request: Better scheduling with Duplicati - #8 by drwtsn32
