I’ve installed Duplicati and the mono frameworks, but when I go to launch it from the Applications folder in the finder, nothing happens.
I ensured that Gatekeeper is set to allow all software to run, regardless of publisher.
I tried running from the terminal and I get the following output…
juno:~ user$ /Applications/Duplicati.app/Contents/MacOS/duplicati
Server has started and is listening on 127.0.0.1, port 8200
Request error: System.Net.WebException: Error: NameResolutionFailure
at Duplicati.Library.Utility.AsyncHttpRequest+AsyncWrapper.GetResponseOrStream () [0x0004d] in <1cb5198b00f34ae59d97ee7fe7a3a16c>:0
at Duplicati.Library.Utility.AsyncHttpRequest.GetResponse () [0x00044] in <1cb5198b00f34ae59d97ee7fe7a3a16c>:0
at Duplicati.GUI.TrayIcon.HttpServerConnection.PerformRequestInternal[T] (System.String method, System.String endpoint, System.Collections.Generic.Dictionary`2[TKey,TValue] queryparams) [0x001ca] in <d07129d6974642b0bbdaa3ccc42fe89d>:0
at Duplicati.GUI.TrayIcon.HttpServerConnection.PerformRequest[T] (System.String method, System.String urlfragment, System.Collections.Generic.Dictionary`2[TKey,TValue] queryparams) [0x00035] in <d07129d6974642b0bbdaa3ccc42fe89d>:0
at Duplicati.GUI.TrayIcon.HttpServerConnection.UpdateStatus () [0x00001] in <d07129d6974642b0bbdaa3ccc42fe89d>:0
at Duplicati.GUI.TrayIcon.HttpServerConnection..ctor (System.Uri server, System.String password, System.Boolean saltedpassword, System.Boolean dbPasswordSourceDatabase, System.Collections.Generic.Dictionary`2[TKey,TValue] options) [0x000de] in <d07129d6974642b0bbdaa3ccc42fe89d>:0
at Duplicati.GUI.TrayIcon.Program.RealMain (System.String[] _args) [0x003d7] in <d07129d6974642b0bbdaa3ccc42fe89d>:0
I’m not sure what the name resolution failure is referring to, so if there are any other diagnostics required to provide more information, let me know.
Mono version is:
juno:~ user$ /Library/Frameworks/Mono.framework/Commands/mono --version
Mono JIT compiler version 5.4.0.201 (2017-06/71277e78f6e Thu Sep 21 19:22:55 EDT 2017)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
TLS: normal
SIGSEGV: altstack
Notification: kqueue
Architecture: amd64
Disabled: none
Misc: softdebug
LLVM: yes(3.6.0svn-mono-master/8b1520c8aae)
GC: sgen (concurrent by default)
…and Duplicati is version 2.0.2.1
