For the folder "C:\Users\Sanitiy\HESSENBOX\#Aktuelle Daten" I have setup a backup.
In it there’s a sub-directory “C:\Users\Sanitiy\HESSENBOX\#Aktuelle Daten\Latex-Scripts und Zusammenfassungen”,
which for some reason is missing in the backups.
Alternatively (but maybe harder), you can make a log file at verbose level to see why it’s skipped, however depending on backup file count this either makes a big file, or doing a scaled-down test.
If it’s not an attribute, I think verbose level makes other messages about source paths it handles.
@ts678 You were right - it is actually marked as System folder. Though I have no idea how this could have happened - you can’t even set that attribute in the property dialog of windows, so I have no idea how this might have happened.
I don’t know your software, so don’t know if folder is considered “owned” by that app or you, but typical Windows application has a lot of ability to set attributes the way it sees fit, e.g. by use of:
We sometimes see applications choose file attributes that the user wasn’t expecting. I’m not sure what can be done about it. A different area that could be improved would be that the GUI invites:
and it’s not obvious that these are attributes. At least CLI exclude-files-attributes makes it clear:
Use this option to exclude files with certain attributes. Use a comma separated list of attribute names to specify more than one. Possible values are: ReadOnly, Hidden, System, Directory, Archive, Device, Normal, Temporary, SparseFile, ReparsePoint, Compressed, Offline, NotContentIndexed, Encrypted, IntegrityStream, NoScrubData.
