Bigun
#1
Immediately when trying to run a job the following error is thrown:
The type initializer for ‘Duplicati.Library.DynamicLoader.DynamicLoader`1’ threw an exception.
No other logs seem to be generated.
edit
Digging around I see more weird behavior, it seems all backup destination types in the drop-down menu are empty.
Also, source is a x86 Gentoo linux environment, and the target is Raspbian via SFTP.
What version of Duplicati and what version of mono?
Bigun
#3
Duplicati 2.0.5.1
Mono 6.6.0.161
Has it ever worked properly for you? Or are you setting it up for the first time?
Bigun
#5
It has worked in the past, it stopped working after a system update.
Bigun
#6
I just realized a different error is thrown to the screen when it opens:
The type initializer for 'Duplicati.Library.DynamicLoader.CompressionLoader' threw an exception.
Bigun
#7
Unsure what the issue was, but I rebooted the server for an unrelated reason, and the backups started working again.
