I have a server “S” with duplicati with a reachable SSH connection, with data I want to save to an other machine “M” that has no possible direct connection to.
I initiate a first ssh connection from “M” to “S” with Remote port forwarding
On machine “M” : ssh -R 2222:127.0.0.1:22 “user”@“server”
Through this connection I want to start a duplicati backup.
This backup using SSH/SFTP connection to “M”
But I do not manage to …
No connection when I use the “connection test” on 192.168.0.202 port 2222
“S” local ip “192.168.0.202”
“S” docker ip “172.19.0.2/16”
What I tried :
- on “S”, I manage to : ssh -p 2222 user@127.0.0.1 but not 192.168.0.202 ?
- on “S”, in duplicati connection OK on 192.168.0.202 port 22
- on “S”, in duplicati connection NotOK on 192.168.0.202 port 2222
- disabling all iptables with “iptables -F” => no change
Would you have an idea to make it work ?
Other information :
I use compose file :
services:
duplicati:
image: lscr.io/linuxserver/duplicati:latest
container_name: duplicati
user: root
environment:
- PUID=0
- PGID=0
- TZ=Etc/UTC
# - CLI_ARGS= #optional
volumes:
- XXXXX/config:/config
ports:
- 8200:8200
restart: unless-stopped
The network used with the container is “compose_yml_default”
docker network inspect compose_yml_default
"Name": "compose_yml_default",
"Id": "b8948c6b7c8e1a664a4ef01d252be0af13bff2f9b26adb729d9ebf009a43075d",
"Created": "2024-03-26T15:22:30.584406947+01:00",
"Scope": "local",
"Driver": "bridge",
"EnableIPv6": false,
"IPAM": {
"Driver": "default",
"Options": null,
"Config": [
"Subnet": "172.19.0.0/16",
"Gateway": "172.19.0.1"
"Internal": false,
"Attachable": false,
"Ingress": false,
"ConfigFrom": {
"Network": ""
"ConfigOnly": false,
"Containers": {
"e1b774e5fb8fea8fb64bff6a09118c4dd7de9ab576b20e2a0d6690a6a6f590fc": {
"Name": "duplicati",
"EndpointID": "20117f4c654ab3e709b4e6311fdd30b7746b63a3f11975e93259ba4ed60ac0a9",
"MacAddress": "02:42:ac:13:00:02",
"IPv4Address": "172.19.0.2/16",
"IPv6Address": ""
"Options": {},
"Labels": {
"com.docker.compose.network": "default",
"com.docker.compose.project": "compose_yml",
"com.docker.compose.version": "2.25.0"
