Ha! Looks like --symlink-policy = Follow should do the trick. Thanks, will try.
Is it case sensitive? Is it " --symlink-policy = Follow or --symlink-policy = follow?
You don’t have to use symlinks if you don’t want to. You can map as many folders as you want into the docker container, and you can use any location, it doesn’t have to be /source.
On my Duplicati docker container I think I have 8 mappings to the host machine.
If you don’t have to use symlinks then great, if you do.
--symlink-policy=Follow
Case does not seem to matter and extra spaces seem to get striped when I add them in the GUI but will likely cause issues if your trying to script things so I’d suggest avoiding spaces when possible.
FYI: You can open the GUI, create a dummy job (or edit an existing one), go to Step 5 where you can add an advanced option from the dropdown, configure said advanced option to your liking, then click on the three vertical dots and choose “Edit as text” to see how those advanced options are specified in text.
