Duplicati -> homeassistant via nodered/mqtt
Wanted to share what I have done in order to make information about my Duplicati backups available in Home Assistant.
My set-up uses node-red to get backup info, and publish it to mqtt which Home Assistant will pick up.
It is possible to launch a backup via Home Assistant and monitor the progress.
Feel free to try it out. Note that I’m new in nodered and mqtt, so I might not have used the best practices.
Regards,
Wim
