Hi @lankanmon, welcome to the forum!
I am running Duplicati in an unRAID Docker, but am only backing up a small amount of data and only to a local share (on the unRAID box) and haven’t had any issues since the initial setup was completed.
It sounds like you may have had at least one successful backup run to one of your destinations, but it’s a bit clear from the errors you provided which destination(s) were throwing which errors.
I’d recommend we start by focusing on a single destination. Once we get that working we can look at the other one.
For your Local Share backup, have you gotten any backup to work? More specifically, is there anything backed up that you care about or is it OK to wipe it and start over?
If that Local Share backup, what Volume Size (dblock) are you using? It’s possible your Docker mappings are pointing to paths that don’t have enough storage to handle temp file requirements or the job sqlite database size.
These are usually associated with the user cancelling a backup - did you do that at all on the 9th, 10th or 11th?
Mar 9, 2018 9:45 PM: Error in worker
System.Threading.ThreadAbortException
Mar 9, 2018 9:45 PM: Failed while executing "Backup" with id: 1
Mar 10, 2018 12:25 PM: Error in worker
Mar 10, 2018 12:25 PM: Failed while executing "Backup" with id: 1
Mar 11, 2018 1:55 PM: Failed while executing "Backup" with id: 2
Duplicati.Library.Interface.CancelException: Cancelled
This usually happens when SOME Duplicati files from successful backups are deleted from the destination.
Mar 11, 2018 9:05 AM: Failed while executing "Backup" with id: 1
Duplicati.Library.Interface.UserInformationException: Found 229 files that are missing from the remote storage, please run repair
Mar 11, 2018 2:00 PM: Failed while executing "Backup" with id: 1
Mar 11, 2018 3:48 PM: Failed while executing "Backup" with id: 1
This usually happens when ALL Duplicati files from successful backups are deleted from the destination OR the destination has been changed (such as pointing ot a new folder).
Mar 11, 2018 3:49 PM: Failed while executing "Repair" with id: 1
Duplicati.Library.Interface.UserInformationException: No files were found at the remote location, perhaps the target url is incorrect?
These usually happen when the user has started a database repair but it got interrupted somehow (user cancelled, power outage, out of disk space, Docker container updated/recycled, etc.).
Mar 11, 2018 3:49 PM: Failed while executing "Backup" with id: 1
Duplicati.Library.Interface.UserInformationException: The database was attempted repaired, but the repair did not complete. This database may be incomplete and the backup process cannot continue. You may delete the local database and attempt to repair it again.
