Hello
Excuse my English, I do not speak well.
I’m running Ubuntu 18.04 and I installed Duplicati 2.0.3.3
I can not launch it anymore.
It mills a moment and then nothing.
I launched it from the terminal and got this error message.
To test I created a new user and I installed Duplicati.
With this new user, I manage to launch it.
Can you help me ?
Thank you in advance.
Pascal
"Crash!
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Exception: Une erreur critique s'est produite dans Duplicati: System.Exception: Unable to start up, perhaps another process is already running?
Error message: System.Exception: The lock file was locked, but the locking process did not respond to the start command
at Duplicati.Server.SingleInstance..ctor (System.String appname, System.String basefolder) [0x00259] in <670b0e4a9ae144208688fcb192d20146>:0
at Duplicati.Server.Program.RealMain (System.String[] _args) [0x002f7] in <670b0e4a9ae144208688fcb192d20146>:0
at Duplicati.Server.Program.RealMain (System.String[] _args) [0x00327] in <670b0e4a9ae144208688fcb192d20146>:0 ---> System.Exception: Unable to start up, perhaps another process is already running?
at Duplicati.Server.Program.RealMain (System.String[] _args) [0x00729] in <670b0e4a9ae144208688fcb192d20146>:0
at (wrapper managed-to-native) System.Reflection.MonoMethod:InternalInvoke (System.Reflection.MonoMethod,object,object[],System.Exception&)
at System.Reflection.MonoMethod.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x00038] in <8f2c484307284b51944a1a13a14c0266>:0
at System.Reflection.MonoMethod.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x00053] in <8f2c484307284b51944a1a13a14c0266>:0
at System.Reflection.MethodBase.Invoke (System.Object obj, System.Object[] parameters) [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0
at Duplicati.Library.AutoUpdater.UpdaterManager.RunMethod (System.Reflection.MethodInfo method, System.String[] args) [0x00000] in <9ce928d8db224e1f8330a80e119b5dbe>:0
Unhandled Exception:
at Duplicati.Library.AutoUpdater.UpdaterManager.RunMethod (System.Reflection.MethodInfo method, System.String[] args) [0x00097] in <9ce928d8db224e1f8330a80e119b5dbe>:0
at Duplicati.Library.AutoUpdater.UpdaterManager+<>c__DisplayClass58_0.<RunFromMostRecentSpawn>b__0 () [0x00000] in <9ce928d8db224e1f8330a80e119b5dbe>:0
at Duplicati.Library.AutoUpdater.UpdaterManager.WrapWithUpdater (Duplicati.Library.AutoUpdater.AutoUpdateStrategy defaultstrategy, System.Action wrappedFunction) [0x00157] in <9ce928d8db224e1f8330a80e119b5dbe>:0
at Duplicati.Library.AutoUpdater.UpdaterManager.RunFromMostRecentSpawn (System.Reflection.MethodInfo method, System.String[] cmdargs, Duplicati.Library.AutoUpdater.AutoUpdateStrategy defaultstrategy) [0x0004b] in <9ce928d8db224e1f8330a80e119b5dbe>:0
at Duplicati.Library.AutoUpdater.UpdaterManager.RunFromMostRecent (System.Reflection.MethodInfo method, System.String[] cmdargs, Duplicati.Library.AutoUpdater.AutoUpdateStrategy defaultstrategy) [0x0001b] in <9ce928d8db224e1f8330a80e119b5dbe>:0
at Duplicati.GUI.TrayIcon.Program.Main (System.String[] args) [0x0001c] in <ca93296e82084f80be4b4a222197f416>:0
Crash!
at Duplicati.GUI.TrayIcon.HostedInstanceKeeper..ctor (System.String[] args) [0x00093] in <ca93296e82084f80be4b4a222197f416>:0
at Duplicati.GUI.TrayIcon.Program.RealMain (System.String[] _args) [0x002a8] in <ca93296e82084f80be4b4a222197f416>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.Exception: Une erreur critique s'est produite dans Duplicati: System.Exception: Unable to start up, perhaps another process is already running?
at Duplicati.GUI.TrayIcon.Program.Main (System.String[] args) [0x0001c] in <ca93296e82084f80be4b4a222197f416>:0 "
