Hi, two of my four backups on local Win10 machine with Duplicati 2.0.5.1_beta_2020-01-18 fail, because database is in use by another process. However, that another process is duplicati itself. It basically keeps itself deadlocked by trying to access database it already opened.
Restarting service didn’t helped. Other two backup - and only difference is frequency of saving and paths they backup - run correctly. Exporting backup configuration, deleting it and importing it back also helps, but I kinda hope that is not the solution.
Can duplicati be told to not deadlock itself?
