Thanks @kenkendk
Yes last backups to Storj completed back in August, these backups have been in place for almost 2 years. I did not have Duplicati set to auto start so it has not actually been running probably between around August and this week when I restarted it.
Do you mean --http-readwrite-timeout=1h? Doesn’t seem to make any difference.
Here are the logs after starting the job and having the web ui stop straight after each. Did it twice to show the pattern of logs. These are from the docker terminal.
Uptime on the docker container is 28 hours.
Connection to localhost (127.0.0.1) 8200 port [tcp/*] succeeded!
Server has started and is listening on port 8200
fail: Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddleware[1]
An unhandled exception has occurred while executing the request.
Duplicati.WebserverCore.Exceptions.NotFoundException: No active backup
at Duplicati.WebserverCore.Endpoints.V1.ProgressState.Execute()
at lambda_method245(Closure, EndpointFilterInvocationContext)
at Duplicati.WebserverCore.Middlewares.HostnameFilter.InvokeAsync(EndpointFilterInvocationContext context, EndpointFilterDelegate next)
at Duplicati.WebserverCore.Middlewares.LanguageFilter.InvokeAsync(EndpointFilterInvocationContext context, EndpointFilterDelegate next)
at Microsoft.AspNetCore.Http.RequestDelegateFactory.<ExecuteValueTaskOfObject>g__ExecuteAwaited|129_0(ValueTask`1 valueTask, HttpContext httpContext, JsonTypeInfo`1 jsonTypeInfo)
at Duplicati.WebserverCore.Middlewares.WebsocketExtensions.<>c__DisplayClass0_0.<<UseNotifications>b__0>d.MoveNext()
at Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddlewareImpl.<Invoke>g__Awaited|10_0(ExceptionHandlerMiddlewareImpl middleware, HttpContext context, Task task)
Inside getter
Inside getter
Inside getter
System.NullReferenceException: Object reference not set to an instance of an object.
at Duplicati.Server.Scheduler.get_WorkerQueue()
at Duplicati.Server.Scheduler.GetSchedulerQueueIds()
at WebserverCore.Services.SchedulerService.GetSchedulerQueueIds()
at Duplicati.WebserverCore.Services.StatusService.GetStatus()
at Duplicati.WebserverCore.Notifications.WebsocketAccessor.SendInitialStatus(WebSocket connection)
at Duplicati.WebserverCore.Notifications.WebsocketAccessor.AddConnection(WebSocket newConnection)
warn: Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddleware[2]
The response has already started, the error handler will not be executed.
fail: Microsoft.AspNetCore.Server.Kestrel[13]
Connection id "0HN8U8CAVMIHI", Request id "0HN8U8CAVMIHI:00000001": An unhandled exception was thrown by the application.
at Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddlewareImpl.HandleException(HttpContext context, ExceptionDispatchInfo edi)
at Duplicati.WebserverCore.Middlewares.StaticFilesExtensions.<>c__DisplayClass5_0.<<UseDefaultStaticFiles>b__1>d.MoveNext()
at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpProtocol.ProcessRequests[TContext](IHttpApplication`1 application)
Unhandled exception. System.NullReferenceException: Object reference not set to an instance of an object.
at Duplicati.WebserverCore.Notifications.WebsocketAccessor.<.ctor>b__4_0(Object _, EventArgs _)
at System.Threading.Tasks.Task.<>c.<ThrowAsync>b__128_1(Object state)
at System.Threading.QueueUserWorkItemCallback.Execute()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading.PortableThreadPool.WorkerThread.WorkerThreadStart()
Inside getter
