Duplicati-cli backup error
I am not sure if this is a bug or user error because I am new to Duplicati. I am running a backup with the following command using version 2.0.2.1_beta_2017-08-01. (On another note, is this a solid version or should I be testing with another one?)
duplicati-cli backup b2://<bucketName> '/path-to-directory/' --b2-accountid '<acctID>' --b2-applicationkey '<appKey>'
When I run this I get the following error:
System.IO.IOException: The source folder /path-to-directory/<acctID> does not exist, aborting backup
  at Duplicati.Library.Main.Controller+<>c__DisplayClass16_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) <0x7fa8a37178 + 0x00b6c> in <filename unknown>:0
  at Duplicati.Library.Main.Controller.RunAction[T] (Duplicati.Library.Main.T result, System.String[]& paths, IFilter& filter, System.Action`1 method) <0x7fa9edd000 + 0x00173> in <filename unknown>:0
So why is it adding the accountID to the path? Something seems very odd. Is this a bug or did I do something wrong?
TIA!
In case it is not clear from my post, all of the data encapsulated in ‘<>’ are actual information from B2. I removed them from the post for security purposes, but you should assume that all of those include correct information from B2.
Duplicati uses --option=value , so you need to replace some spaces with = marks. Also, depending on your shell, you need to use double quotes instead of single quotes:
duplicati-cli backup "b2://<bucketName>" "/path-to-directory/" --b2-accountid="<acctID>" --b2-applicationkey="<appKey>"
These instructions solved it and it is now working properly.
Thank you!
