Duplicati C Drive full
The reformatting happens at backup time. A simplified explanation is at The backup process explained.
Because you’re already talking dblock files, you might also want a more technical version (ignore if not):
How the backup process works
How the restore process works
Yes.
Restore uses the destination contents to restore data of original folders and files as you requested it to.
Taken literally, question makes no sense, as the destination folder does not contain the raw source file.
If you seek a file copy program or a file sync program, this isn’t it. Please read Overview and Features.
Duplicati takes backups, each of which is a snapshot of files. For restore, you pick what time you want.
Restoring files from a backup shows how this looks in the GUI. Please try things when you are able to.
I have no idea where things are now, because no answers are coming back. This makes helping hard.
To answer a less literal version of the question, because a backup version is a snapshot of the source, changes to source are reflected in that particular version of the backup. This might be adds, deletes, or modifications. All of this is stored in a compact way for many versions, thanks to the destination format.
The log in the GUI summarizes change:
What do you want to move? Again, please be clear. You seem in a rush, so try to explain well first time.
At the moment, this is going nowhere…
No, if you delete a file in the source (accidental or not) it will not be removed from existing backups, of course because the file no longer exist it won’t be included in any future backups so make sure your retention policy is sufficient for your needs. The default policy keeps all backups.
If it did delete the file reactively, that would make it a sync program and not a backup program.
FYI: There are ways to purge files from existing backups but that’s not typical thing most people want or need to do.
How to purge files ?
My duplicati configuration
Now, please check and help me with my issue as soon as possible
Thank You
Complete Log
“DeletedFiles”: 0,
“DeletedFolders”: 0,
“ModifiedFiles”: 0,
“ExaminedFiles”: 71827,
“OpenedFiles”: 0,
“AddedFiles”: 0,
“SizeOfModifiedFiles”: 0,
“SizeOfAddedFiles”: 0,
“SizeOfExaminedFiles”: 118077096165,
“SizeOfOpenedFiles”: 0,
“NotProcessedFiles”: 0,
“AddedFolders”: 0,
“TooLargeFiles”: 0,
“FilesWithError”: 0,
“ModifiedFolders”: 0,
“ModifiedSymlinks”: 0,
“AddedSymlinks”: 0,
“DeletedSymlinks”: 0,
“PartialBackup”: false,
“Dryrun”: false,
“MainOperation”: “Backup”,
“CompactResults”: null,
“VacuumResults”: null,
“DeleteResults”: {
“DeletedSetsActualLength”: 0,
“DeletedSets”: [],
“Dryrun”: false,
“MainOperation”: “Delete”,
“ParsedResult”: “Success”,
“Version”: “2.0.6.102 (2.0.6.102_canary_2022-04-06)”,
“EndTime”: “2022-04-29T17:59:55.3021627Z”,
“BeginTime”: “2022-04-29T17:59:47.9728686Z”,
“Duration”: “00:00:07.3292941”,
“MessagesActualLength”: 0,
“WarningsActualLength”: 0,
“ErrorsActualLength”: 0,
“Messages”: null,
“Warnings”: null,
“Errors”: null,
“BackendStatistics”: {
“RemoteCalls”: 5,
“BytesUploaded”: 0,
“BytesDownloaded”: 110629066,
“FilesUploaded”: 0,
“FilesDownloaded”: 3,
“FilesDeleted”: 0,
“FoldersCreated”: 0,
“RetryAttempts”: 0,
“UnknownFileSize”: 0,
“UnknownFileCount”: 0,
“KnownFileCount”: 2178,
“KnownFileSize”: 113370308159,
“LastBackupDate”: “2022-04-29T22:00:00+05:30”,
“BackupListCount”: 5,
“TotalQuotaSpace”: 0,
“FreeQuotaSpace”: 0,
“AssignedQuotaSpace”: -1,
“ReportedQuotaError”: false,
“BeginTime”: “2022-04-29T17:56:45.8875665Z”,
“Duration”: “00:00:00”,
“Messages”: null,
“Warnings”: null,
“Errors”: null
“RepairResults”: null,
“TestResults”: {
“MainOperation”: “Test”,
“VerificationsActualLength”: 3,
“Verifications”: [
“Key”: “duplicati-20220427T133001Z.dlist.zip”,
“Value”: []
“Key”: “duplicati-i0bf20813d13e4c9990c733f034437533.dindex.zip”,
“Value”: []
“Key”: “duplicati-bb07bb7b516fb4173a280726098306ad8.dblock.zip”,
“Value”: []
“EndTime”: “2022-04-29T18:00:22.5854282Z”,
“BeginTime”: “2022-04-29T17:59:58.9904217Z”,
“Duration”: “00:00:23.5950065”,
“Messages”: null,
“Warnings”: null,
“Errors”: null,
“RemoteCalls”: 5,
“BytesUploaded”: 0,
“FilesUploaded”: 0,
“FilesDeleted”: 0,
“RetryAttempts”: 0,
“Messages”: null,
“Warnings”: null,
“Errors”: null
“ParsedResult”: “Warning”,
“Duration”: “00:03:36.6978617”,
“MessagesActualLength”: 17,
“WarningsActualLength”: 8,
“Messages”: [
“2022-04-29 23:26:56 +05 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started”,
“2022-04-29 23:27:09 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()”,
“2022-04-29 23:27:14 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (2.13 KB)”,
“2022-04-29 23:29:47 +05 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-StartCheck]: Start checking if backups can be removed”,
“2022-04-29 23:29:47 +05 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-FramesAndIntervals]: Time frames and intervals pairs: 7.00:00:00 / 1.00:00:00, 28.00:00:00 / 7.00:00:00, 365.00:00:00 / 31.00:00:00”,
“2022-04-29 23:29:48 +05 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-BackupList]: Backups to consider: 29-04-2022 21:35:09, 27-04-2022 19:00:01, 26-04-2022 18:14:10, 24-04-2022 21:39:37”,
"2022-04-29 23:29:48 +05 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-BackupsToDelete]: Backups outside of all time frames and thus getting deleted: ",
"2022-04-29 23:29:48 +05 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-AllBackupsToDelete]: All backups to delete: ",
“2022-04-29 23:29:55 +05 - [Information-Duplicati.Library.Main.Operation.DeleteHandler-DeleteResults]: No remote filesets were deleted”,
“2022-04-29 23:29:55 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()”,
“2022-04-29 23:29:58 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (2.13 KB)”,
“2022-04-29 23:29:59 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-20220427T133001Z.dlist.zip (5.41 MB)”,
“2022-04-29 23:30:04 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Completed: duplicati-20220427T133001Z.dlist.zip (5.41 MB)”,
“2022-04-29 23:30:04 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-i0bf20813d13e4c9990c733f034437533.dindex.zip (134.92 KB)”,
“2022-04-29 23:30:05 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Completed: duplicati-i0bf20813d13e4c9990c733f034437533.dindex.zip (134.92 KB)”,
“2022-04-29 23:30:05 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-bb07bb7b516fb4173a280726098306ad8.dblock.zip (99.96 MB)”,
“2022-04-29 23:30:22 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Completed: duplicati-bb07bb7b516fb4173a280726098306ad8.dblock.zip (99.96 MB)”
“Warnings”: [
“2022-04-29 23:27:25 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: D:\OneDrive - Chirag Nahata\Computer Backup\D Drive\Wamp\Projects\woocommerce\packages\woocommerce-blocks\src\Payments\Integrations\”,
“2022-04-29 23:27:35 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: D:\OneDrive - Chirag Nahata\Computer Backup\D Drive\Wamp\Projects\woocommerce\packages\woocommerce-blocks\src\Payments\Integrations\”,
“2022-04-29 23:27:42 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: D:\OneDrive - Chirag Nahata\Computer Backup\D Drive\Wamp\Projects\tagyourtaxi-10\codecanyon-34028175-tagyourtaxi-taxi-application-uber-clone-android-dashboard\main-file\server-app\app\Http\Requests\Taxi\Owner\”,
“2022-04-29 23:28:02 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: D:\OneDrive - Chirag Nahata\Computer Backup\D Drive\Wamp\Projects\tagyourtaxi-10\codecanyon-34028175-tagyourtaxi-taxi-application-uber-clone-android-dashboard\main-file\server-app\app\Http\Requests\Taxi\Owner\”,
“2022-04-29 23:28:04 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: D:\OneDrive - Chirag Nahata\Computer Backup\D Drive\Wamp\Projects\salepro-334nulled\codecanyon-22256829-lims-stock-manager-pro-with-pos\vendor\twilio\sdk\Twilio\Rest\Taskrouter\”,
“2022-04-29 23:28:25 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: D:\OneDrive - Chirag Nahata\Computer Backup\D Drive\Chirag Nahata\Projects\Python\Jarvis\env\Lib\site-packages\async_timeout\”,
“2022-04-29 23:28:39 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: D:\OneDrive - Chirag Nahata\Computer Backup\D Drive\Wamp\Projects\salepro-334nulled\codecanyon-22256829-lims-stock-manager-pro-with-pos\vendor\twilio\sdk\Twilio\Rest\Taskrouter\”,
“2022-04-29 23:29:10 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: D:\OneDrive - Chirag Nahata\Computer Backup\D Drive\Chirag Nahata\Projects\Python\Jarvis\env\Lib\site-packages\async_timeout\”
“Errors”: [],
“RemoteCalls”: 5,
“BytesUploaded”: 0,
“FilesUploaded”: 0,
“FilesDeleted”: 0,
“RetryAttempts”: 0,
“Messages”: null,
“Warnings”: null,
“Errors”: null
Are you trying to Duplicati to back up another backup (Computer Backup\D Drive) that’s already stored in a cloud backup location (OneDrive)?
In general I would not back up the OneDrive folder as it may trigger downloads of the files to your local machine. OneDrive folders are already “backed up” by the OneDrive service. But if you don’t care if the files will get downloaded, and you have room on your D: drive, then it should technically work I think.
Both the onedrive accounts are different.
Why is that error message coming ?
Error message :
  • 2022-05-11 13:19:29 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataGenerator.Metadata-MetadataProcessFailed]: Failed to process metadata for “C:\hiberfil.sys”, storing empty metadata
  • 2022-05-11 13:19:29 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataGenerator.Metadata-MetadataProcessFailed]: Failed to process metadata for “C:\pagefile.sys”, storing empty metadata
  • 2022-05-11 13:19:29 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\hiberfil.sys
  • 2022-05-11 13:19:29 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\pagefile.sys
  • 2022-05-11 13:19:29 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataGenerator.Metadata-MetadataProcessFailed]: Failed to process metadata for “C:\swapfile.sys”, storing empty metadata
  • 2022-05-11 13:19:29 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\swapfile.sys
  • 2022-05-11 13:19:30 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: C:\Windows\WUModels\
  • 2022-05-11 13:19:30 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataGenerator.Metadata-MetadataProcessFailed]: Failed to process metadata for “C:\Windows\diagerr.xml”, storing empty metadata
  • 2022-05-11 13:19:30 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Windows\diagerr.xml
  • 2022-05-11 13:19:30 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataGenerator.Metadata-MetadataProcessFailed]: Failed to process metadata for “C:\Windows\diagwrn.xml”, storing empty metadata
  • 2022-05-11 13:19:30 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Windows\diagwrn.xml
  • 2022-05-11 13:19:30 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataGenerator.Metadata-MetadataProcessFailed]: Failed to process metadata for “C:\Windows\WUModels”, storing empty metadata
  • 2022-05-11 13:20:34 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: C:\Windows\Temp\vmware-SYSTEM\
  • 2022-05-11 13:20:38 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: C:\Windows\SysWOW64\Tasks\
  • 2022-05-11 13:20:38 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: C:\Windows\SysWOW64\sru\
Log :
“DeletedFiles”: 2860,
“DeletedFolders”: 473,
“ModifiedFiles”: 949,
“ExaminedFiles”: 312974,
“OpenedFiles”: 6418,
“AddedFiles”: 5469,
“SizeOfModifiedFiles”: 2720924430,
“SizeOfAddedFiles”: 5182388033,
“SizeOfExaminedFiles”: 129934621986,
“SizeOfOpenedFiles”: 8001389299,
“AddedFolders”: 684,
“TooLargeFiles”: 0,
“AddedSymlinks”: 0,
“Dryrun”: false,
“CompactResults”: {
“DeletedFileCount”: 0,
“DownloadedFileCount”: 0,
“UploadedFileCount”: 0,
“DeletedFileSize”: 0,
“DownloadedFileSize”: 0,
“UploadedFileSize”: 0,
“Dryrun”: false,
“MainOperation”: “Compact”,
“EndTime”: “2022-05-11T08:07:41.6693638Z”,
“BeginTime”: “2022-05-11T08:07:29.6453073Z”,
“Duration”: “00:00:12.0240565”,
“Messages”: null,
“Warnings”: null,
“Errors”: null,
“RemoteCalls”: 100,
“BytesUploaded”: 4644913612,
“BytesDownloaded”: 132943404,
“FilesUploaded”: 90,
“FilesDeleted”: 5,
“RetryAttempts”: 0,
“KnownFileCount”: 1075,
“KnownFileSize”: 55997497441,
“LastBackupDate”: “2022-05-11T13:18:09+05:30”,
“BeginTime”: “2022-05-11T07:48:08.7670372Z”,
“Messages”: null,
“Warnings”: null,
“Errors”: null
“DeleteResults”: {
“DeletedSetsActualLength”: 1,
“DeletedSets”: [
“Item1”: 3,
“Item2”: “2022-05-11T00:03:08+05:30”
“Dryrun”: false,
“CompactResults”: {
“Dryrun”: false,
“Messages”: null,
“Warnings”: null,
“Errors”: null,
“RemoteCalls”: 100,
“FilesDeleted”: 5,
“RetryAttempts”: 0,
“Messages”: null,
“Warnings”: null,
“Errors”: null
“BeginTime”: “2022-05-11T08:07:10.3254992Z”,
“Duration”: “00:00:31.3438646”,
“Messages”: null,
“Warnings”: null,
“Errors”: null,
“RemoteCalls”: 100,
“FilesDeleted”: 5,
“RetryAttempts”: 0,
“Messages”: null,
“Warnings”: null,
“Errors”: null
“TestResults”: {
“Verifications”: [
“Key”: “duplicati-20220511T064259Z.dlist.zip”,
“Value”: []
“Key”: “duplicati-i6619e50b74df478d993f58e899ea0614.dindex.zip”,
“Value”: []
“Key”: “duplicati-b4c126079277c4474ad9c05f8fbbbb528.dblock.zip”,
“Value”: []
“EndTime”: “2022-05-11T08:08:30.8955715Z”,
“BeginTime”: “2022-05-11T08:07:48.2532336Z”,
“Duration”: “00:00:42.6423379”,
“Messages”: null,
“Warnings”: null,
“Errors”: null,
“RemoteCalls”: 100,
“FilesDeleted”: 5,
“RetryAttempts”: 0,
“Messages”: null,
“Warnings”: null,
“Errors”: null
“EndTime”: “2022-05-11T08:08:30.9091037Z”,
“Duration”: “00:20:22.1420665”,
“MessagesActualLength”: 216,
“WarningsActualLength”: 1575,
“Messages”: [
“2022-05-11 13:18:08 +05 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started”,
“2022-05-11 13:18:40 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()”,
“2022-05-11 13:18:45 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (990 bytes)”,
“2022-05-11 13:18:45 +05 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-KeepIncompleteFile]: keeping protected incomplete remote file listed as Temporary: duplicati-20220511T064258Z.dlist.zip”,
“2022-05-11 13:18:45 +05 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-Remove incomplete file]: removing incomplete remote file listed as Uploading: duplicati-b5bfb4f3f14c544fab7d21ac5b01374bb.dblock.zip”,
“2022-05-11 13:18:45 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Delete - Started: duplicati-b5bfb4f3f14c544fab7d21ac5b01374bb.dblock.zip ()”,
“2022-05-11 13:18:48 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Delete - Completed: duplicati-b5bfb4f3f14c544fab7d21ac5b01374bb.dblock.zip ()”,
“2022-05-11 13:18:52 +05 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-Remove incomplete file]: removing incomplete remote file listed as Uploading: duplicati-ba4450b25659b43e9b75c940f56f73594.dblock.zip”,
“2022-05-11 13:18:52 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Delete - Started: duplicati-ba4450b25659b43e9b75c940f56f73594.dblock.zip ()”,
“2022-05-11 13:18:52 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Delete - Completed: duplicati-ba4450b25659b43e9b75c940f56f73594.dblock.zip ()”,
“2022-05-11 13:18:55 +05 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-Remove incomplete file]: removing incomplete remote file listed as Uploading: duplicati-b709f465dd2f743aa801c222aacfc21df.dblock.zip”,
“2022-05-11 13:18:55 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Delete - Started: duplicati-b709f465dd2f743aa801c222aacfc21df.dblock.zip ()”,
“2022-05-11 13:18:56 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Delete - Completed: duplicati-b709f465dd2f743aa801c222aacfc21df.dblock.zip ()”,
“2022-05-11 13:18:59 +05 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-Remove incomplete file]: removing incomplete remote file listed as Uploading: duplicati-b477e423ec78d40cba5776e715a1ef603.dblock.zip”,
“2022-05-11 13:18:59 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Delete - Started: duplicati-b477e423ec78d40cba5776e715a1ef603.dblock.zip ()”,
“2022-05-11 13:19:00 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Delete - Completed: duplicati-b477e423ec78d40cba5776e715a1ef603.dblock.zip ()”,
“2022-05-11 13:19:03 +05 - [Information-Duplicati.Library.Main.Operation.Backup.UploadSyntheticFilelist-PreviousBackupFilelistUpload]: Uploading filelist from previous interrupted backup”,
“2022-05-11 13:25:12 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b87bab60628c4445b814d8b3865298db9.dblock.zip (99.92 MB)”,
“2022-05-11 13:25:12 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b33d38c226e6549a2b91052548056afed.dblock.zip (99.96 MB)”,
“2022-05-11 13:25:12 +05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b03dd4f0a7b8f4094bc018d2587727a09.dblock.zip (99.91 MB)”
“Warnings”: [
“2022-05-11 13:19:29 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataGenerator.Metadata-MetadataProcessFailed]: Failed to process metadata for “C:\hiberfil.sys”, storing empty metadata”,
“2022-05-11 13:19:29 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataGenerator.Metadata-MetadataProcessFailed]: Failed to process metadata for “C:\pagefile.sys”, storing empty metadata”,
“2022-05-11 13:19:29 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\hiberfil.sys”,
“2022-05-11 13:19:29 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\pagefile.sys”,
“2022-05-11 13:19:29 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataGenerator.Metadata-MetadataProcessFailed]: Failed to process metadata for “C:\swapfile.sys”, storing empty metadata”,
“2022-05-11 13:19:29 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\swapfile.sys”,
“2022-05-11 13:19:30 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: C:\Windows\WUModels\”,
“2022-05-11 13:19:30 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataGenerator.Metadata-MetadataProcessFailed]: Failed to process metadata for “C:\Windows\diagerr.xml”, storing empty metadata”,
“2022-05-11 13:19:30 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Windows\diagerr.xml”,
“2022-05-11 13:19:30 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataGenerator.Metadata-MetadataProcessFailed]: Failed to process metadata for “C:\Windows\diagwrn.xml”, storing empty metadata”,
“2022-05-11 13:19:30 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Windows\diagwrn.xml”,
“2022-05-11 13:19:30 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataGenerator.Metadata-MetadataProcessFailed]: Failed to process metadata for “C:\Windows\WUModels\”, storing empty metadata”,
“2022-05-11 13:20:34 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: C:\Windows\Temp\vmware-SYSTEM\”,
“2022-05-11 13:20:38 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: C:\Windows\SysWOW64\Tasks\”,
“2022-05-11 13:20:38 +05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: C:\Windows\SysWOW64\sru\”
“Errors”: [],
“RemoteCalls”: 100,
“FilesDeleted”: 5,
“RetryAttempts”: 0,
“Messages”: null,
“Warnings”: null,
“Errors”: null
