To be more specific for anyone struggling, @kees-z 's solution worked for me, but the specifics for what I had to enter for the domain-my and name_domain_com fields was a little ambiguous.
If you go to the online OneDrive Business page, then look at the URL, you will see something like
https://domain-my.sharepoint.com/personal/name_domain_ac_uk/_layouts/15/onedrive.aspx
From this, you can see exactly what you need to enter.
(In my case it was ac_uk, not com, because I’m a UK University student)
Additionally, it’s extremely important you ensure the end of the ‘Path on Server’ ends with Documents/FOLDER_NAME, I omitted the Documents directory, but if you miss this out you will find the files will upload without error but disappear to the ether! I just wasted over 24 hours uploading 500GB on a 20Mbps connection only for all the files to be missing because I missed the Documents text. ‘Documents’ is infact the root of your OneDrive.
