Duplicati 2.1.0.2 beta - No Tray Icon kernel32.dll-Error
Hello,
I just installed Duplicati 2.1.0.2 beta on a server and there is no Tray Icon. Even manually started it does not appear. Event log show following error:
Name der fehlerhaften Anwendung: Duplicati.GUI.TrayIcon.exe, Version: 2.1.0.2, Zeitstempel: 0x66470000
Name des fehlerhaften Moduls: KERNELBASE.dll, Version: 10.0.17763.6530, Zeitstempel: 0x2853070e
Ausnahmecode: 0xe0434352
Fehleroffset: 0x0000000000041b39
ID des fehlerhaften Prozesses: 0x924
Startzeit der fehlerhaften Anwendung: 0x01db5ae06ced1292
Pfad der fehlerhaften Anwendung: C:\Program Files\Duplicati 2\Duplicati.GUI.TrayIcon.exe
Pfad des fehlerhaften Moduls: C:\Windows\System32\KERNELBASE.dll
Berichtskennung: 5a4738d3-47dd-406d-bb55-3cdcd87cfaf0
Vollständiger Name des fehlerhaften Pakets:
What is the problem?
Greetings,
Zusch
Do you have any detailed error from the application event log just before the event you show?
How? Good would be at a Command Prompt, which may be another way to get error message.
If it doesn’t say anything at all, that’s another clue. You could also see if its help command runs.
What if anything was running fine before 2.1.0.2? If a new installation, how far could you get it? Previous time someone had one of these, they had somehow gotten the encryption messed up. Awhile back, someone had found a bug in a backup run. Do you have any scheduled backups?
Unfortunately the old Duplicati-crashlog.txt feature is missing from this Beta (back in 2.1.0.100).
