Duplicati 2.1.0.2_beta_2024-11-24
Hello, I have a problem with the options on all os, win, linux, mac
- –send-http-url=https://192.168.2.228:8080/
- –send-http-result-output-format=Json
- –accept-specified-ssl-hash=XXXXXXXXXXXXXXXXXXXXXXXX
- –accept-any-ssl-certificate=true
a telegraph is working on the host 192.168.2.228:8080 which forwards the JSON to an InfluxDB and is evaluated by Grafana.
After the update to v2.1.0.2_beta_2024-11-29 the Sender JSON no longer works. Settings are the same as in v2.0.8.1_beta.
the log shows this message:
2025-01-08 08:40:35 -05 - [Warning-Duplicati.Library.Modules.Builtin.SendHttpMessage-HttpResponseError]: HTTP Response request failed for: https://192.168.2.228:8080/
System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure: RemoteCertificateNameMismatch, RemoteCertificateChainErrors
at System.Net.Security.SslStream.SendAuthResetSignal(ReadOnlySpan`1 alert, ExceptionDispatchInfo exception)
at System.Net.Security.SslStream.CompleteHandshake(SslAuthenticationOptions sslAuthenticationOptions)
at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](Boolean receiveFirst, Byte[] reAuthenticationData, CancellationToken cancellationToken)
at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(QueueItem queueItem)
at System.Threading.Tasks.TaskCompletionSourceWithCancellation`1.WaitWithCancellationAsync(CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)
at Duplicati.Library.Modules.Builtin.SendHttpMessage.SendMessage(HttpClient client, SendRequestType target, String subject, String body)
2025-01-08 08:40:35 -05 - [Warning-Duplicati.Library.Modules.Builtin.ReportHelper-ReportSubmitError]: Failed to send message: System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
at Duplicati.Library.Modules.Builtin.SendHttpMessage.SendMessage(String subject, String body)
at Duplicati.Library.Modules.Builtin.ReportHelper.OnFinish(Object result, Exception exception)
Under Duplicali up to 2.0.8.1_beta the JSON are sent. From 2.0.9 and .Net8 no longer.
