I use 2.0.2.1_beta_2017-08-01 on my Laptop since 2 months any problem.
Since yesterday, I try to use it on my other computer, in the same configuration (backup to a USB HD).
During a first backup, I stop it to add an option (prefix name).
I deleted first backup files created.
I try to start the job, but it was not a good thing to delete files.
I tried to repair the database, I received error. Finally, I think it was ok.
When I start manualy the job, now, the backup file are created in %TEMP%, and not in my destination path !
I deleted the job 2 times, same issue.
I uninstalled and reinstalled Duplicati ( 2.0.2.1_beta_2017-08-01 ), same issue.
I expect a miracle if you remove the compression level setting (deprecated) and change the value of zip-compression-level to 1 (or even 0 to disable compression completely).
Remove the compression-extension-file setting to stick to the default list of excluded extensions for compression. If you don’t specify a filename, or the specified file contains incorrect information, all files (including uncompressable files like .JPG or .ZIP) will be recompressed without any beneficial effect.
You can also remove the zip-compression-method setting, because Deflate is the default setting.
Duplicati still uses a single processor core for processing blocks, hashing, compression and uploading to the backend. The default compression level is known to be a relative resource-intensive task. Decreasing the compression level to 1 is reported to improve overall speed with the downside of using a bit more storage space.
AFAIK, parallel processing is worked on, so in the future overall backup speed may increase, even when using higher compression levels.
